Old 1st June 2009, 08:18 PM   #1
Question What's the Second coil do?
Greetings all, I have been browsing the boards for a while and have learned an incredible amount of stuff. Now I have a question that I'm sure somebody here can answer.
I purchased a Xover from Partsexpress, (the cheapo unit), and although it does what I want, (tweeter is just a little brighter than I like), I am having trouble wrapping my tiny brain around the reason for the 2nd coil. It's in the same circuit (sort of) as the Cap but I'm not sure if it is actually needed or why it's in the circuit. See attached pic
Thanks ahead of time.
Music is art, Audio is engineering
Old 1st June 2009, 08:34 PM   #2
Might help if I post the pic of the backside also.
Old 1st June 2009, 08:37 PM   #3
Dr.EM is offline Dr.EM  United Kingdom
Dr.EM's Avatar
With what appears like 2 coils and one cap, and with this being a 2 way crossover, I can only assume it employs assymetrical slopes. Most likely 6db woofer and 12db tweeter slopes. If it were one of each it'd be 6db for both.
EDIT: Having now seen the back I'm fairly certain that's right. 12dB tweeter slope and 6dB woofer slope
Old 1st June 2009, 08:38 PM   #4
Speakerholic
Cal Weldon's Avatar
The woofer appears to have a 6dB roll off whereas the tweeter uses a 12db. The second coil is used to bypass the tweeter and better protect it.
EDIT: The good Dr. answered whilst I was a typin'
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 1st June 2009, 08:39 PM   #5
5th element's Avatar
Indeed, it looks like a 1st order on the woofer and 2nd on the tweeter.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Droggon Attack!
Old 1st June 2009, 08:40 PM   #6
Speakerholic
Cal Weldon's Avatar
That's a record. 3 answers in two minutes, AND they're all the same!
Old 1st June 2009, 09:39 PM   #7
EDIT: The good Dr. answered whilst I was a typin' [/B]
I didn't expect such fast responses. Thanks everyone! It makes since now. Fascinating stuff.
Old 1st June 2009, 09:58 PM   #8
badman is offline badman  United States
Custom Title
badman's Avatar
Feel the love. Now, don't be a stranger! There are a lot of great people here and an amazing amount of group knowledge, though on the finer points, there's often disagreement (audibility of enclosures anyone? EnAbl?)
If I'd known about this place sooner, my early designs would have been better. First speakers I built, "edge diffraction whaaa?"
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned!
Old 1st June 2009, 10:05 PM   #9
Speakerholic
Cal Weldon's Avatar
Originally posted by badman
Feel the love.
Well said. Without this place, I'd think baffle step compensation involved time alignment of the drivers.
Old 2nd June 2009, 01:49 AM   #10
Yes I agree. It seems the greatest variables are opinions. I've found it best to read carefully, listen closely, and do the math. The greatest reward is to come back here and give away the knowledge gained. (oh... and end up with some great sounding speakers also)
Thanks again.
Single Voice Coil Vs Double Voice Coil Subwoofer Workhorse Car Audio 6 12th April 2007 06:36 AM
ASV voice coil ? Nihilist Multi-Way 4 1st October 2006 07:16 PM
Coil woes xstephanx Subwoofers 7 2nd January 2005 02:17 AM
Damaged coil? Flappytango Multi-Way 6 8th February 2004 02:12 AM
Page generated in 0.14384 seconds (76.27% PHP - 23.73% MySQL) with 11 queries
