hi!! I have a pair of Yamaha NS-150 speakers and one of the tweeters died some days ago. So, I decided to mod the speakers to do some improvements.
Instead of replacing the tweeters with the original ones (really difficult to get a new one in Argentina) I decided to change the tweeters from 1" silk dome to Audax TW010F1 tweeters. After opening the enclosure of the speakers I realized that the crossover is made with electrolitic capacitors So, I need some advice before starting. What improvements can I do to the speakers? I'm planning to: - change the tweeters to this ones: http://www.madisound.com/catalog/pro...products_id=96 - change the electrolitic capacitors with MKP capacitors what do you thinnk? |
#2 |
That tweeter isn't suitable, It doesn't respond down low enough for the 2Khz crossover point.
This is much better, for not much more money: http://www.madisound.com/catalog/pro...oducts_id=1496 You'll need to change C3 and L3 for the new tweeter, and to put in a padding resistor so that the tweeter's ouput is the same as the mid-woofer 6 uF, 1mH, & 2.2 ohms seem to be a good starting point, for a tweeter impedance of 6.5 ohms and 3dB pad
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky |
#3 |
Speakerholic
The K1 you linked to is a great deal. Tough as nails and not bad sounding. Hard to find a better deal out there.
#4 |
thanks for your answers.
Too late, I have alredy bought the tweeters,... Is there anything I can do to adapt the crossover to use this tweeters? By the way, I'm going crazy trying to open the speakers enclosure, it seems that all the wooden is sealed with some kind of glue and I cant find screws.... If I cant open them, will be really difficult to modify the crossovers |
| modding Yamaha NS-150. Measuring small-thiele parameters & new crossover | zafira1981 | Multi-Way | 7 | 2nd August 2009 03:04 AM |
| Mods to Yamaha NS-10 Speakers???? | Mark A. Gulbrandsen | Multi-Way | 20 | 7th October 2008 07:18 PM |
| Advice in Yamaha PC2002 | artcarmo | Solid State | 5 | 29th August 2008 06:05 AM |
| modding my Klipsch KG-2.5's- some advice | trespasser_guy | Multi-Way | 0 | 27th June 2003 05:03 AM |
| modding old 3-way speakers | supes | Multi-Way | 8 | 18th March 2003 08:27 PM |
| Page generated in 0.10625 seconds (67.71% PHP - 32.29% MySQL) with 11 queries |
