Old 31st May 2009, 03:44 AM   #1
tim0850 is offline tim0850  Australia
Default change seas 2 way to 3 way
i have built a sealed version of zaph's seas l15 design.J:\tim\dipoles\ZaphAudio l15.htm i have also built romans seas l22 bass module. http://www.rjbaudio.com/Astorius/astorius.html currently i am simply running a 100uf cap to the l15 to intergrate the 2 units. in theory this crosses at romans designed 250 hz. any suggestions for a more elegant crossover.
Old 31st May 2009, 11:16 PM   #2
Moondog55's Avatar
The easy way to do it would probably buy a good plate amp with features, such as the "O-Audio"
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING"
Old 31st May 2009, 11:49 PM   #3
tinitus is offline tinitus  Europe
Yeah, but now you are attempting a 3way crossover, and all sorts of strange things may happen, such as difficult phase issues
You need to get the series cap(100uf) exactly right, and optimally have a paralel inductor too
I like to use resistor in series with paralel coil(resistor to ground)
But big inductors cost money, and if you need several to find the right one it gets even more costly
But size matters
Moondog suggests a plateamp
Could be crossed low
You have made mains closed, so you may not need any highpass on them(100uf)
If you want a higher 3way xo point
One option could be the new interesting Hypex 2way plateamps, but more costly
Ehh, maybe not much more than 2 subplateamps
If you can live with those amps
But crosed high active you need at least the possible choice of different slopes
And optimally be able to design your own slopes
I dont know what the new digital filter can do
Old 4th June 2009, 06:34 AM   #4
thanks for the replies. i put 50uf cap in series and 8.2mh coil in parallel. in theory this is the right crossover for a a 250hz crossover on a 6.5ohm midrange. sounds better. any further comments
Old 4th June 2009, 10:21 AM   #5
OK
Only, the theoretical correct(calculated) size in particular I dare say is the one and only that with certainty is not likely to work
Old 6th July 2009, 05:30 AM   #6
ended up with 40 uf cap inseries and 6.8 coil in parallel for a 300hz xover
Old 6th July 2009, 07:08 AM   #7
Moondog55's Avatar
Most important question, how does it sound?
If it's working for you that is the most important issue.
Seas 27TDFC H1189 vs Seas 27TFFC H881 ermes Multi-Way 4 19th April 2011 01:20 PM
chooseing Seas Cygnet or others seas kits juanito Multi-Way 0 20th July 2009 12:27 PM
Wanted: Seas W17EX001, Usher 8945P, Seas CA18, or somewhat similar mid-woofer. Spasticteapot Swap Meet 2 7th March 2007 04:06 PM
Seas Millenium tweeters and Seas W22EX-001 sephiroth619 Swap Meet 2 5th March 2007 06:34 AM
Seas Excel W26 compaired to Seas L26 (10&quot;) harruharru Subwoofers 9 11th March 2005 09:47 PM
Page generated in 0.08956 seconds (73.48% PHP - 26.52% MySQL) with 10 queries
