Following some research on acoustic resonances, it was brought to my attention that the enclosure air-spring becomes non-linear beyond a certain level of compression. Therefore the Maximum SPL (below an arbitrary distortion threshold) attainable by a system is thus dictated by the volume of air within the enclosure.
Dennis H over on HTGuide provided a useful formula for determining distortion relating to air compression: Distortion % = 140*(one-way driver displacement)*(1/enclosure volume) What are the causes for this form of distortion? Is it due to the temperature decay or the pressure imbalance between sides of the diaphragm? How can we decrease this phenomenon? Thanks, Thadman
"It is a profound and necessary truth that the deep things in science are not found because they are useful; they are found because it was possible to find them." |
#2 | ||
se |
#3 | |
#4 | |
#5 |
In most cases, the air in the box is more linear than your driver's suspension. It is when the driver volume displacement exceeds 10% of the box volume that it will become significant. Still, whether it is more significant than driver nonlinearity depends on the driver.
Transmission lines pressurize a box, so they are affected.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan |
#6 | |
#7 |
It is really rather elementary stuff. Given the same SPL at the same frequency, the degree of pressurization will be the same in a sealed, vented, PR, TL, etc.... The proof is left to you as an exercise...
#8 | |
P = C/V thus dP/dV = -C/V^2 Since dP/dV is the spring constant this means that even an ideal gas is a non-linear spring. |
#9 | |
Is it then possible to accurately determine an enclosures air spring force and model it? Even with acoustic foam or rigid fiberglass present?
#10 |
You may be able to do that to some extent with some drivers by adding a small DC offset to the signal to compensate with the driver suspension linearity. Not really recommended.
| DAC linearity test CD | oshifis | Digital Source | 52 | 22nd May 2012 11:27 PM |
| Linearity | maxpou | Solid State | 42 | 8th February 2008 10:44 PM |
| improve the linearity | E007 | Solid State | 1 | 3rd May 2004 09:23 AM |
| Non-linearity of wattage to SPL... | JoeBob | Everything Else | 5 | 21st February 2002 07:47 PM |
| Page generated in 0.14768 seconds (67.03% PHP - 32.97% MySQL) with 10 queries |
