Having devoted myself to amplifiers for the last year , I have neglected the loudspeaker end of the chain. Now that I have a rock solid 200w+ of symasym power, I felt the need to move some air.
At the thrift shop today I "landed' a pair of these... ![]() 1 little chip on box , all the drivers work , a nearly perfect Sharp 15" 3-way pair for 30$. ![]() http://www.parts-express.com/pe/show...number=290-175 The tweeter also performed nicely at high levels. The dirt cheap mid sounded strained with "classical thunder". ![]() ![]() I looked at the Xover and they had a silly little board with 1- 2.2uf and a 15uF cap .. that's the Xover.. also, the woofer had no coil (inductor), so I assume standard 1.5k / 5k crossover points. I feel with a better midrange and a real crossover , much better performance could be realized with this 3.4cu ft. monster. I know it is a cheaper OEM ("rent -a- center" on back) , but my wife takes all my money. Any suggestions on a better mid and crossover (I can make boards) would be appreciated.OS |
#2 |
Good buy!
Do you intend keeping the existing cabinets??
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING" |
#3 | |
The mids have to go , Cheeeeep , I saw these... http://www.parts-express.com/pe/show...number=280-115 ![]() Still cheap , but much lower Fs (470) and better construction. I only paid 30$ for the whole thing , so I just want "bang for the buck" OS |
#4 |
Those woofers are quite decent, not top-of-the-line, or "boomers", but a nice quality bass. They're worth more than you paid... and even the boxes can be upgraded at a later point. I'm doing that to a 2.5cf pair of cheap 5/8" JVC boxes I got free... I stripped off the vinyl, and am going to glue 1/2" solid pine over the 5/8" particle board.
I'm going to turn one side of the boxes to the front, and make those the front baffle... I cut a roughly 12" plug to fill the hole where the woofer was, and will glue/screw that to the inside of the pine sides. Gonna cut a hole to fit a 8" woofer, and a port, and build a separate midwoofer/tweeter enclosure. Good luck... and enjoy those however you use 'em!! |
#5 |
I'd try and get a pair of the sealed back Peerless mids, the units with the integral enclosure, similar vintage, use the box in the current orientation and just make the usual improvements with corner braces and fiberfill
#6 |
I've often listened to speakers at friends houses like that and thought these aren't THAT bad. But the "big tweeter" mid range would have to go.
#7 |
I would like to hear that woofer looks nice.
spl woofer 96 dB 1wmtr your mid 90dB 1wmtr this can't fit nice. this mid you use Use this Hivi dome spl 93dB 1wmtr 2" dome cone 92dB 1 wmtr cone mid pioneer pylepro The best 94dB 1 wmtr pioneer $19 And filter 2 oct 3way $34 So ask your wife 110$ back
( (( KUGELWELLE )) ) recent projects :OB-mk1 /fatboy / monitor-xl / Horn-AM / dappolito / td124-mk1-rb301 / Hybrid-pse / Vfet |
#8 | |
This one is just to fill the time before the real one is built.I have brand new Hitachi table saw / router , 10 years of custom kitchen/ cabinetry experience. OS |
#9 | |
Your woofer is very nice combine a nice dome tweeter and maybe a 94dB 1Wmtr tweeter and make a good cabinet and your ready.
#10 | |
This I realize , that is why I said the mid that's in it has to go (super cheep).
I will order this instead , perfect fit , kind of cheap , too. http://www.parts-express.com/pe/show...number=280-115 Quote:
The pioneer woofer DOES sound good , just a little "muddy" at the mid-bass , no doubt the lack of a XO !
| Page generated in 0.15696 seconds (63.60% PHP - 36.40% MySQL) with 10 queries |
