Found it today in a painters shop. Only E 12,95 for 1/2 a killo and even got a
discount as we agreed I was an artist Paverpol
http://tda1541a.com The Final List |
#2 |
And even a 3 year old can use it
#3 |
Speakerholic
Being that it dries 'rock hard' might that lower the cone breakup frequency?
#4 |
All depends on the speaker and what you want to achieve I guess.
As paper damps more and stiffer materials less some might benefit and some might not. I'll try it on some to see what happens A light coating will keep some of the paper damping and change the breakup points either to the bad or the good side. I'll do some measurements before and after but even then, this again depends on the speaker used, damping material, x-over etc.
#5 |
frugal-phile(tm)
It could be useful in some applications. Something i tend to avoid is stuff that dries stiff, and the rock hard has me concerned. To me that means resonant peak, even if there wasn't one, but depending on other physical properties (how much mass is added) would push a resoanance up in frequency. Might be useful in subbs.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#6 |
frugal-phile(tm)
modpodge/puzzlekoat is a PVA compound that remains flexible after drying.
dave
#7 |
That's why this one is 'the other'
call it rock hard right now. Let's see in a few days. And indeed might be useful on subs and older speakers in a three way when you can avoid breakup at the x-over level.
#8 |
Still quite flexible and not rockhard at all. Feels a bit rubbery even and I can
poke a finger through the basket, press really hard up to the point the voicecoil wants to break out and it still comes back in it's original form. No sign of cracking where the finger poked even when pressed hard. Flexing part of the cone really hard with one inch between two fingers does not bother it as well. Makes for one extremely childproof speaker
| First experience with Mod Podge | loninappleton | Full Range | 8 | 19th November 2008 03:13 PM |
| Mod Podge and Micro Gloss | BHD | Full Range | 19 | 13th November 2007 01:25 PM |
| Audax PR170M0 and breakup modes - diluted PVA glue, damar, Mod Podge... ? | Saurav | Multi-Way | 32 | 18th June 2004 06:00 AM |
| Page generated in 0.08481 seconds (76.26% PHP - 23.74% MySQL) with 11 queries |
