I have been immensely curious what type of tranmission line would be suitable for the Lambda TD12M. I own a pair and the idea is quite appealing in many ways.
I don't have Martin's software because he isn't sharing it anymore (actually I have the old free one, but not MathCAD). Would it trouble you to model such a driver so I could take a look at what the results would look like? The driver specs for the TD12M are here: TD12M - 8ohm Fs: 38.1Hz Qms: 2.99 Vas: 140L Cms: .35mm/N Mms: 50g Rms: 4kg/s Xmax: 6mm Sd: 531sqcm Qes: .27 Re: 6.6 Le: .2mH Z: 8ohm Bl: 17Tm Pe: 500W Qts: .25 1W SPL: 96.5dB |
#2 |
Josh I had Paul do a work up last week on the TD12M and after much fiddling he said it just won't work well do to the low Qts.
#3 |
Thanks Brandon. I used the tables and couldn't figure it out either. Thought it just might not be flexible enough for said driver.
#4 |
Maybe then the Faital 12PR300 that is on sale might be a better candidated for a TL. I don't want to ask others to do a work up on a list of drivers. I was just curious about the ones I had.
http://www.usspeaker.com/faital%20pro%2012pr300-1.htm |
#5 | |
Maybe GM has some tricks up his sleeves that are better or more numerous than mine and can come up with a workable TL for the TD12M?!
#6 |
Well certainly the high output Z of a SE tube amp which I am using will help, but it seems like it might not be enough. I'd rather not force a solution and instead find the appropriate tool for the job.
#7 | |
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#8 |
Truth is I don't know. I could calculate it but local feedback obscures (to me) the math. Its Pete Millett's SE KT88 E-linear amp.
#9 |
Ask him then.........
GM
#10 |
I asked him some other questions before about the design and he said he lost his notes on it.
| Beyma tpl-150 + Lambda TD12M's | studiotech | Multi-Way | 21 | 24th July 2009 12:51 PM |
| AE TD12M cheap alternative - Faital 12PR300? | Defo | Multi-Way | 60 | 13th June 2009 12:21 AM |
| JBL 2206H vs. Lambda TD12M | Defo | Multi-Way | 10 | 27th March 2009 11:34 PM |
| Ping SY | JoshK | Tubes / Valves | 32 | 27th March 2009 12:12 PM |
| Ping SY | moray james | Planars & Exotics | 3 | 16th June 2005 04:39 PM |
| Page generated in 0.48207 seconds (18.13% PHP - 81.87% MySQL) with 10 queries |
