Old 21st May 2009, 02:34 PM   #1
rudy129 is offline rudy129  United States
Default Speaker Enclosure
If using two woofers in an enclosure calling for 28 liter each volume, does it make a difference sonically if you construct the enclosure as one unit multiplying the volume by two...or should you separate each 28 liter area internally?
Old 21st May 2009, 04:52 PM   #2
badman is offline badman  United States
Custom Title
badman's Avatar
Most studies have indicated that it's not an issue whether you build them separately or together, as far as performance is concerned. I'd build them separate for a couple reasons. The separator is going to act as a shelf brace, there will be less concern with box modes as the (likely vertical) 1 dimension will be halved, making a higher frequency resonance that's more easily damped, and also, in a failure situation, you'll have more airspring protection on the remaining driver if one blows.
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned!
Speaker enclosure calculations cumesoftware Multi-Way 7 19th May 2008 01:58 PM
speaker for 2 litre enclosure? Nanook Multi-Way 5 13th May 2007 03:04 AM
WTB: Speaker enclosure Destroyer OS. Swap Meet 5 3rd October 2006 07:48 PM
How do I know the best speaker for an enclosure? dohhhhh6 Subwoofers 2 3rd June 2005 06:19 PM
Right Sub for Speaker Enclosure Xyberz Multi-Way 3 9th September 2002 01:03 PM
Page generated in 0.07146 seconds (70.23% PHP - 29.77% MySQL) with 10 queries
