Hi!
I am looking for my first DIY project and im looking for a good TL-design that is quite easy to build and that doesnt exeed $350 for drivers and crossovers. I'd like 5" drivers or larger. I have browsed and googled the net and have found many different designs but this is the best one so far: http://www.iplacoustics.co.uk/s3tlm%...0Magnesium.htm. Its £200 or $250 for drivers and crossover parts. So they are cheap and should be pretty good after what i have read. Is there any other projects or kits out there that can satsify my love for TL-speakers? I quite like my current TL-speakers and love the rolloff at 20hz. Im not counting on that in the new kit though Espen |
#2 |
http://www.geocities.com/cc00541/Tritrix_pg_1.html
http://www.htguide.com/forum/showthread.php4?t=29626 Very good. Way, way better than the investment would suggest.
MG |
#3 |
Thanks, this looks very interesting.
the price here is unmatched i would think, so ill just check availability in Norway. Guess ill have to buy the stuff online anyway. I still want other examples if anyone has got some more. |
#4 |
Visation have a few designs that might be worth looking at:
http://www.visaton.com/en/bauvorschlaege/index.html
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky |
#5 |
I haven't heard these, but the guy that runs this company makes amazing amplifiers so he knows a thing or two about sound...
http://www.aksaonline.com/products/p...s_Vsonics.html
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig. |
#6 |
Thuis last kit looks good, and im sure they are good too. Price is a little bit more than i can take atm.
If i decide to find a set of speakers that should replace mye current speakers, then i will consider the Vsonics. We move to a new apartment in a couple of months, so maybe my needs wil change by then |
#7 |
Holly Crossover Costs Batman!
Those Vsonics work out to $1,017 US dollars and you still have to buy the drivers and cabinet materials! That's one expensive crossover! After buying the wood and drivers, your in Thor territory.... Ron
"If it doesn't work properly, hope it catches on fire"- Nelson Pass @ BA3 "I fired up the prototype. Literally." The Prophet Pass. |
#8 |
I too am looking for a TL design to try, never heard one but hope to soon. I was looking at the IPL site as posted in earlier post, price I think is quite reasonable.
I remember seeing a few months back a design on someones website for a VIfa powered TL. I am going to try to find it again and if I find it I will post it. I have a pair of Scanspeak 18W/8546 (?) drivers (7 Inch Kevlar I think from a pair of Scanspeak Monitors I built many moons ago that I could also "repurpose". There is also an Alpha TL design brief around. I need to look at that again as well.
None of us are leaving this world alive. Enjoy it responsibly as you may. |
#10 | |
frugal-phile(tm)
The Alpha TL generates a not wholly optimum box. Plug the ScanSpeak data into MJKs tables and you'll be way ahead. I like to use the fairly heavily tapered ones... that helps the terminus low pass function so you can get more bottom out of a smaller line. dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
| cheap,easy box design | chainenoble | Multi-Way | 1 | 11th June 2005 04:03 PM |
| Show it again, because easy, cheap and good! | destroyer X | Solid State | 3 | 4th June 2004 07:51 PM |
| Easy-Cheap-DIY-SMD mounting guide. | Brian Guralnick | Parts | 11 | 30th September 2003 07:16 PM |
| first easy cheap ect... | theChris | Parts | 5 | 31st January 2003 07:00 AM |
| Any PCB - easy and cheap | Koy | Solid State | 8 | 17th July 2001 02:45 PM |
| Page generated in 0.13842 seconds (70.71% PHP - 29.29% MySQL) with 10 queries |
