Nasty Room Resonances in New Listening Room Nasty Room Resonances in New Listening Room - diyAudio
Old 18th May 2009, 04:48 PM   #1
TubeHead Johnny is offline TubeHead Johnny  United States
TubeHead Johnny's Avatar
Default Nasty Room Resonances in New Listening Room
Hi Guys,
A few months back, I had my system dialed in just about perfectly. Now I just moved into a new place and the bass sounds like crap. Some bass notes are strongly emphasized, while others you can hardly hear. I'm pretty sure the problem lies in the listening room, which is almost a cube. Actually, it's more like 14' X 13', with a 10' ceiling.
The speakers are 12" in a 3.6 cu in box, tuned to 29 Hz. They're 14" away from the back wall, and 8" off the floor.
Is there anything I can do??
~~~John~~~
Old 18th May 2009, 04:54 PM   #2
MisterTwister is offline MisterTwister  Tibet
soft furniture, pillows, curtains, soft wall decorations, all will help.
Old 18th May 2009, 06:27 PM   #3
Andersonix is offline Andersonix  Sweden
Andersonix's Avatar
Have you thought about a bass equalizer, like Rod Elliott's?
His parametric EQ might be even more suitable.
Old 23rd May 2009, 07:42 PM   #4
After some experimenting, I tamed the bass problem. First I sat the boxes on chairs about 2 feet off the floor...that didn't work. Then I lengthened the port an extra 1.5" for a total of 10.5", that helped a little, but still the bass was way out of control on loud passages. Then I stuffed a softball sized ball of "Acousta Stuf" (PE) down each port and it seems to sound fine now.
I know I effectively raised the Fb, making more like a sealed box, but why is it when I raise the Fb by shortening the tube, it just sounds boomy??
John.
Old 23rd May 2009, 11:13 PM   #5
auplater is offline auplater  United States
auplater's Avatar
Default Room modes
here is a (simplified) layout off your room modes
4.25m x 4.0m x 3.1m
http://www.mcsquared.com/metricmodes.htm
perhaps you're exciting fewer modes with the new config... as u can see, both the axial and tangential modes tend to be bunched around 40 hz and 60 hz respectively,and multiples thereof... pretty boomy region
"I've forgotten more than I care to remember" The Last Conspirators
Nasty Room Resonances in New Listening RoomHide this!Advertise here!
Speakers in corners - room resonances rick57 Everything Else 1 22nd November 2004 08:35 AM
Room resonances Positron Tubes / Valves 28 12th December 2003 03:27 AM
Listening room ding Everything Else 4 18th October 2001 01:20 AM
Copyright ©1999-2017 diyAudio
