#21 | |
If an enclosure resonance is imparting a force on the cone, wouldn't it be possible to feed the driver coil an electrical signal equivalent to the resonance in amplitude but of opposite phase. The forces cancel and the effects of the resonance on the frequency response are gone.
"It is a profound and necessary truth that the deep things in science are not found because they are useful; they are found because it was possible to find them." |
#22 |
Hi Thadman,
I think this paper is relevant to the topic. http://www.fesb.hr/~mateljan/arta/pa...m-aaaa2007.pdf As far as standing waves are concerned, I think a 1.5”- 2” layer of open cell foam covering the internal surfaces of the enclosure will reduce the magnitude/Q sufficiently for them to be considered inaudible. On the other hand, untreated panel resonances in my opinion can be more of a problem, because the surface area of an enclosure is many times greater than the area of the driver’s cone, so panels only need a very small excursion for their acoustic output to equal that from the driver itself. For this reason, I always treat large enclosure panels with bracing. To treat these resonances with some form of processing could help, but personally, I would opt for the solutions above before I resorted to processing techniques, simply because they are so inexpensive to implement. There may be a greater opportunity to limit resonances due to standing waves by processing, because in its simplest form, standing waves exit through the loudspeakers cone. So in spatial terms, they are in a single dimension, however, panel resonances are in three-dimensional space, so processing cannot effectively treat them in my opinion. Regards Peter |
#23 |
Excellent link
#24 |
Interesting paper, nothing new really, but it doesn't say anything about the subject at hand. |
#25 | |
Account Disabled
#26 | |
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#27 |
I have A/B listened to pairs of speakers where one had an external vibration damper attached. The differences WERE audible AND significant.
Despite some of what I've read here, if an enclosure vibrates past some threshold it is audible and undesirable. Vibrating surfaces can make sound - if that surface is the speaker cabinet and not the transducer, artifacts are being added to what reaches the listener's ears that were not in the original recording. At the least I would prefer to overbuild the cabinets and err on the side of caution.
Soft Dome |
#28 | |||
Doing nothing to reduce enclosure vibrations is going to be a problem, but a few key techniques will reduce the sound levels radiated to below the threshold of annoyance (if not audibility). I have tried to measure the amount of sound radiated by the cabinet and found it to be extremely difficult. That makes it, at best, a very small effect. |
#29 | |
I am very much interested in your founding, since they seems in contrast with what Barlow and Stevens found out in theirs 1975 AES preprints: if I remember well, Stevens measured a 10dB difference between the back pannel radiation and the drive output, using an undamped 50 liters box. How much did you measured, and which setup did you used? |
#30 |
Interesting thread...
If I had to pick a single item which has caused me some of the most difficult-to-solve problems in DIY speaker building, it is cabinet resonances. I find I am incredibly sensitive to them. Maybe it's because I owned Magneplanars for many years and I am used to a dipole sound. Despite this, I am not a total torch carrier for the dipole crowd. I also like speakers in cabinets for reasons too numerous to go into here... Both have their strong points. BTW, dipoles DO have undesirable structure resonances. Even Sigfried Linkwitz found this out. Let's talk about the issue of cabinet resonances. It has been proposed that if a cabinet contributed no nonlinearities but had resonances, that with proper filtering, you could avoid exciting these resonances and therefore avoid their audible effects. If a cabinet has a resonance at 300 Hz which augments the output from the speaker at that frequency, one must simply reduce the magnitude of the signal to the speaker by the proper proportion at that frequency and end up with a "flat" frequency response despite the cabinet resonance. Let me start by saying that I have actually used this scheme with some significant measure of success, but it is by no means perfect. Here's why... With the non-linearities of speakers, let's say you put in 2 signals; one at 700 Hz, and one at 1000 Hz. Just one of the most likely of distortion products to come from the speaker is the difference of 1000 - 700 = 300 Hz. This signal is an unplanned-for signal and we did not put it in. There are innumerable combinations of frequencies which, when you put them into our real world speaker driver, give distortion products at 300 Hz. This is why, although you may not be putting IN any frequencies at 300 Hz, intermodulation distortion products will exist at or around 300 Hz which will be augmented by the 300 Hz resonance in our cabinet. This will produce the "resonant signature" which is so immediately identifiable. And remember, the more complex the music is, the more likely it is that the distortion byproducts will coincide with that resonance. That is why using music sources with many voices and/or instruments will so mercilessly reveal cabinet coloration, even when you filter the input signal. |
| Page generated in 0.12082 seconds (90.21% PHP - 9.79% MySQL) with 11 queries |
