#151 | |
I think this a mistatement of the issue. The issue is not listening to low level signals, say 50 dB down, its listening to aberations that are 50 dB BELOW the signal. Thats a vastly different thing. Its this masking that I contend makes the enclosure aspects inaudible despite the fact that you can do all kinds of things to make them audible, but only if you surpress the signal content! |
#152 | |
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#153 | |
dave
#154 | |||
#155 | |
Yes, and what about a listening room aberration that happens to reduce the amplitude of the initial wavefront by, say, 15 db and another listening room aberration that emphasizes the contribution of the panel resonance by, say, 10 db at some hypothetical frequency? Suddenly, the delayed coloration is louder than the initial sound. It appears such considerations have so far been outside of your intellectual envelope. |
#156 |
"...we stumble and get up, we are sad, confident, insecure, feel loneliness and joy and love. There is nothing more; but I want nothing more.” - Christopher Hitchens 1949-2011 |
#157 | ||
Custom Title
But, given a well-behaved time-domain from the drivers themselves, any enclosure ringing that remains when the excitation drops off suddenly will be dramatically higher in relative amplitude. It's not during the dynamic transients- it's immediately after, where the source material is relatively quiet and consists of resonance within the instruments and environment of the recording... resonances with (likely) similar characteristics to those of the enclosure, and with much closer amplitudes. Quote:
But it's possible that you determined via (known flawed, there's no such thing as a 'perfect' measurement) measurements that the enclosure resonances were below an audibility threshold, and that influenced your listening to be willing to ignore them. This is just a flipside of the coin of hearing what you want. I think that much of this hobby is in the finer points, and sometimes they're obscured via short-term measurements. I can't remember an album well after the first listen, or even (usually, if it's music that I deemed worth evaluating) give a good idea of whether I'll enjoy it longer-term. Human auditory memory is known to be short..... But that's based upon short-term testing! Perhaps auditory memory is longer with more time spent with a driver/speaker/system? I know I recognize the 'sound' of speakers and drivers I've long not-heard, if I spent enough time with them. Likewise, there are subtle bits of music that take time to pick up on, and certainly wouldn't happen in a DBT with unfamiliar everything, but once they're recognized, these (typically low-level) information pieces can be critical, and one can be aware that they're altered, even though they're very low level and the alterations even lower. Maybe I'm just slow, but rapid fire evaluation is extremely difficult for me, but I am pretty confident in longer terms. When doing switch-based tests, I meditate before hand, to clear my mind and relax. I have to be very careful to not 'actively' listen as much as 'hear', for the low-level stuff to be clear. The correlation of these shorter-term tests to longer-term experience has only been useful when extreme care to be passive and comfortable and clear-headed are taken. However, the combination of the two gives a great deal of confidence in the results. If I listen to a specific device, swap it in and out a few times over a month or three, then do A/B/A (sometimes DBT, sometimes not) testings in the right fashion, the character I've come to know is much more apparent. Enclosure resonances are tough to eval in this situation. My own experiment consisted of a pair of sealed 8"s, one with dowel braces much like your own bracing and 3/4" void-free ply of mediocre quality, and one with the same enclosed volume and wall thickness of better ply with a few corner chocks and shelf braces. Upon longer term swapping in and out the nicer cab was consistently preferred due to better 'clarity' and 'impact'. This included a few single-blind tests with buddies but nothing more formal. None of this has been done with appropriate documentation, but I think you can relate to doing 'good' experimentation to satisfy your own curiousity without feeling the need to go further with it.
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned! |
#158 | ||
I too take a very long time to decide on anything subjectively regarding sound quality. This is precisely why I gave up going to shows. At one show some guys came into the room, sat down listening to what was probably an unknown piece of music and got up after 15-20 secconds stating "What crap!" One person wouldn't listen because the amp was so bad (although how they knew that was beyond me. I've measured that amp and it actually works quite well.) If thats the evaluation process, then I don't want to be part of it. Yes, there were several other people who spent some time and a couple of them actually bought speakers, but I still have serious concerns over that type of audition. |
#159 |
Custom Title
Unfortunately, "The loop" has open sections on both sides- the hearing mechanism fails, but so does the measurement. And they fail differently...
We're agreed regarding shows. I'm generally able to judge when there's high-quality sound but am very careful to avoid negative judgements due to show conditions, since they are unfamiliar everything, usually. I don't bother with rooms that are really packed, either. Too much distraction and bother. I usually make the rounds many times to try to catch the rooms I'm most interested in when there's a break. And speaking of breaks.... can show organizers PLEASE stop having shows in high-rise hotel venues? It's the worst of all worlds. The old CES and THE show venues were nice because you weren't getting dry-humped by fat audiophiles in the fire-hazard overcrowded hallways. There was outdoor walking area to let your ears and mind relax between exhibits. This was a nice aspect at VSAC 08 as well, there was plenty of opportunity to chill out in the lobby or outside between rooms. I don't think I'll ever bother going to a 'nomal' hotel show again. I've found that at these shows, also, the best sounding rooms are often speakers I wouldn't like. Dynamically restrained "soft" speakers playing the music that suits them, with lots of acoustic treatment. A little break from the pains of overblown demos from many exhibitors.
#160 | |
| Page generated in 0.18284 seconds (84.93% PHP - 15.07% MySQL) with 11 queries |
