#141 | |
I'm pretty sure i know where you are coming from -- if the only tool you have is a hammer, you treat everything like a nail. dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#142 | |
Account Disabled
if that doesn't tell what else? The ear and it's associated brain ain't capable of more. But less. Once again, the response curve IS the system in it's linear part. Anything else is derived from that, You know? so long |
#143 | |
Dave |
#144 | |
You claim such supreme eXPERTise, but you get even simple stuff like this wrong. |
#145 | |
Account Disabled
A) group delay and B) amplitude response That is what I meant could haven been understood as what I mean with "response curve". I wrote it so often in the lenghty way that I had the hope that including You everybody even if of minor expertize would simply know. You may think of it as me trying to set a standart in understanding the word: linear response. And - I do not claim that "expertize". You get it wrong. What I do is to show weaknesses in marketing claims. That doesn't need to much brains. |
#146 | |
#147 | |
Account Disabled
http://www.diyaudio.com/forums/showt...22#post1837922 From that on the talk concentrated on how to identify linear distortion and not to characterize it. Identification could be done with soley amplitude. 'Think we've got it now. |
#148 | |
dave
#149 | |
Grunge isn't a very well defined term. I suspect that no two people would define it the same way. I cannot infer any clear meaning of your definition of it and I doubt that it's quantifiable. How can one argue for/against an ambiguous term? As for the rest, it doesn't provide anything not explained by changes in the linear part of the system response. Small crossover changes can provide changes in the perception that you describe. Painting dots or stripes on a driver make a measurable change in the frequency response that may be perceptible (or not). And I can't recall reading any references you might make to the distortion profile, so it seems fair to assume that you are referring only to the linear response and not any non-linear distortion. Dave |
#150 | |
Custom Title
Arguments of expertise are a fallacy. I have no 'credentials' per se (beyond some years of experience) but can assemble a decent argument on many of the points under discussion. Ignoring "Xpert" is the best route if you're bothered by his behavior. Anyone who uses such a moniker seems to me to be too arrogant for their own good. There's a saying, "The more you know, the more you realize how much you have left to learn" (it's been paraphased dozens of ways). Regarding level perceptibility, testing I've seen was done with non-music signals. That alone separates the test from the usage environment, like a wind-tunnel vs. a racetrack vs. a road with cars. I do a number of tests when testing small items. One of the most important is long-term behavioral. Do I still enjoy the item in question after the novelty has worn off? Do I find myself focusing on one aspect of the sound? Do I listen to more or less music? Obviously it's not an easy test to perform with multiple subjects, and has many factors applied, but that's why it must be longer duration. If my longer-term musical satisfaction increases, more attention is spent on the whys and wherefores. If I find my rig less enjoyable, the change is reversed, or further investigated. Blind testing is an important validation step... sometimes. Just as with the THD wars, the ears have it all over the microphones, as far as musical enjoyment goes.
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned! |
| Page generated in 0.14304 seconds (81.25% PHP - 18.75% MySQL) with 11 queries |
