#131 | |
#132 | |
<i>
I've distinctly heard sheetrock, ductwork, port resonances and panel resonances that are all fairly easy to separate from the original incident waveform from the driver. Not to mention reflections through the cone itself from within the cabinet which can also be detected and suppressed. Suppression of secondary resonant contributions is, for instance, much of the rationale for feedback control at live concerts. |
#133 | |
Custom Title
This argument is like tasting a bell pepper and a habanero, and then someone telling you that there's no reason to believe the habanero is hotter without measuring the capsacin (sp?) levels. These colorations, once identified, are easy for an experienced listener to hear. There are bigger problems around, but an undersized engine in a car doesn't invalidate the usefulness of an improved suspension.
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned! |
#134 | |
Account Disabled
#135 | |
Account Disabled
To investigate the sonic impact of a possible linear disturbance/distortion the one and only thing to do is to look up its trace in the amplitude/group delay vs. frequency plot. With cabinet "resonances" that are down by 20dB or more and that are LINEAR in their relation to the original signal no degradation is expected. The human hearing is by for more forgiving than todays measurement tools. |
#136 | |
frugal-phile(tm)
20 dB is not good enuff for me... dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#137 | |
#138 | |
Account Disabled
U may simply calculate it: a contrubution that is 20dB down and adds linear - as cabinet walls do - will show up as: 10*log10 ( 1 + (10^20/10) ) = 10*log10 (1.01) = fetch Your calculator! in the amplitude response. The impact on group delay will show the same orders of magnitude. If You can hear the difference, You may call for the scientists to investigate Your extraterrestial skills further. no offnece |
#139 | |
frugal-phile(tm)
The ability to hear that fine detail has been evolved into us for millions of years, the ones who couldn't hear that stuff never lived to breed, dave
#140 | |
Account Disabled
U should think it over |
| Page generated in 0.12529 seconds (88.81% PHP - 11.19% MySQL) with 11 queries |
