Old 18th May 2009, 04:01 PM   #1
Default How to determine the best midrange enclosure?
Hi all,
I've not seen much in the way of rules for determining the size of midrange enclosures where a woofer is present. Since many midranges are open back I understand they need to be separated within their own chamber (along with tweeters) but how does one choose the optimal size? Should they be treated like a small woofer? Should dampening material be used? Browsing at some enclosure plans I am confused as most don't explain how the volume of these separate midrange/tweeter chambers were calculated. I figure their size must have some kind of effect on sound. Your advice and opinions are apreciated!
Retroman
Old 18th May 2009, 04:36 PM   #2
Dr.EM is offline Dr.EM  United Kingdom
Dr.EM's Avatar
Basically you can treat them like a small woofer, full TS parameters should be available and when used in a box simulator (ie. WinISD) will give you an appropriate sized enclosure. Sealed is normally always used with mids, not ported, though closed and open ended TL's can work very well as well as open baffles. Usually a Q of 0.7 is used for sealed, this is what the sim will normally calculate initially. A higher Q will lead to peaking (smaller box = higher Q).
Damping material should certainly be used, acoustic foam may also be implemented. Sometimes people like to curve the walls or add irregular patterns to the inside of the enclosure with an aim to break up standing waves.
Old 19th May 2009, 07:36 AM   #3
Henkjan is offline Henkjan  Netherlands
Henkjan's Avatar
the shape of the mid enclosure (internal shape I mean) is also important, if you can avoid the sqare box please do so. iirc there was a thread on this subject ....
Old 19th May 2009, 02:11 PM   #4
Send a message via ICQ to Shefffield
as far as I know midranges are not to be treated like small woofers. Different to woofers midranges are never used near their resonance frequency, but usually at least one octave above that - preferrably even higher.
So the Q in the vicinity of fb is of no interest and can be ignored. What should not be ignored is the frequency of fb in the planned enclosure. Make sure it keeps a safe distance from the frequency band where the mid driver is used.
Additionally, a small, asymmetrical (as Henkjan stated already) enclosure is to be preferred to minimize unwanted effects standing waves. Be aware though that asymmetrical walls will not affect standing waves, the only cure here is to move them out of the used frequency band by minimizing the cave behind the cone.
Be careful with damping material if you use a high efficiency midrange with a very thin, lightweight cone. These are said to be very sensible for mass coupling.
I hope this helps,
Axel
P.S.: I myself am a friend of no enclosure behind the mid driver.
Old 19th May 2009, 05:57 PM   #5
frugal-phile(tm)
planet10's Avatar
It is not often that i'm designing a midrange enclosure, but a mid-tweeter enclosure could be considered the same thing.
I treat it just like a bass driver in some senses, but am not often aiming for as low an extension as possible. A smooth controlled roll-off and control of impedance are my goals, http://www.diyaudio.com/forums/showt...52#post1827952
For this reason i often like to execute a midTL (damping procedure is changed over one aimed at bass)
The LF cutoff of a midrange enclosure can be used as part of the crossover, For instance a sealed box with a Q=0,7 mated with an electrical 2nd order butterworth will give you a 4th order Linkwitz-Riley XO. It is a challenge to execute a passive XO around the sealed box resonance peak.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 19th May 2009, 06:01 PM   #6
Andersonix's Avatar
I thought the mid range driver's enclosure shape was more about preventing reflections back through the cone than preventing standing waves?
Midrange Enclosure Volume lotuss79 Multi-Way 8 15th May 2009 11:39 PM
Midrange enclosure volume and EBP question marscoast Multi-Way 9 16th October 2007 04:12 PM
do i need an enclosure for midrange driver? ironpen45 Multi-Way 3 23rd March 2007 11:12 PM
Question regarding midrange enclosure size? Bogwan Multi-Way 8 1st March 2007 06:52 AM
Tell me about your midrange enclosure please. tade Multi-Way 2 7th February 2006 08:03 PM
Page generated in 0.97069 seconds (9.00% PHP - 91.00% MySQL) with 10 queries
