When I first started learning about speaker design many years ago one of the issues often discussed was paying strict attention to the acoustic center separation of the 2 drivers vs. crossover frequency. It was said that both drivers should be kept as close together as possible, preferably less than than the wavelength of the crossover frequency.
However many speakers seem to ignore this "rule" and particularly in the case of supertweeters crossed over very high it is not possible. However in many cases it does not seem to be detrimental to sound quality according to reviews I have read. I wonder if it's only a serious issue in a narrow passband directly related to the crossover frequency? Where the default separation of drivers is close to the wavelength of the crossover frequency creating odd lobing behavior? But is not a serious issue if the drivers are much further apart or much closer together? |
#2 |
frugal-phile(tm)
The reason that one can often get away with this, is because the XO is way up where the ear is less sensitive.
It can be a real issue with a typicak 2-way where the XO is right in the ears most sensitive area (~1.5-4kHz) dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#3 |
Perhaps, but I think this may be interesting to experiment with when I have some drivers available. If I could find the right (identical) drivers that would allow me to test:
1. Coaxial and time-aligned (the woofer will effect the tweeter wave-launch unless the tweeter is mounted flush or forward of the apex [largest part] of the woofer cone in which case it will need to be time-aligned by other means. 2. Mounted separately so the acoustic centers are equal to the crossover frequency compared to slightly off (also time-aligned). 3. Mounted much further apart compared to the crossover frequency (again time-aligned). Maybe a Neodymium Scanspeak tweeter and 8" Peerless or similar woofer would be good for this experiment with a crossover ~2khz. |
#4 | ||
Low cross-over (1440Hz) dipole with exceptionally beefy tweeter, mid-tweeter (1KHz XO, 3-4" between acoustic centers), coaxial mounting, full range plus back-horn or bass driver. Quote:
#5 | |
Someone should make a flat diaphram woofer with a large diameter voice coil and mount a tweeter in the center. You can make the woofer cone out of honeycomb sandwich with kevlar or carbon fiber, maybe like Eton uses. Use a felt/foam ring around the coaxial tweeter so it doesn't reflect off the woofer diaphram so the woofer excursion doesn't alter the high frequencies. |
#6 | |
| Question on Eros MKII tweeter to woofer separation | andy2 | Multi-Way | 2 | 9th October 2005 04:18 AM |
| How to amplify a tweeter and midrange | nickvda | Multi-Way | 4 | 11th July 2005 08:46 AM |
| Midrange and tweeter enclosures | murat | Multi-Way | 16 | 3rd February 2005 08:32 PM |
| Maximum separation of driver centers vs. frequency to avoid significant lobing | RHosch | Multi-Way | 1 | 19th November 2003 06:37 PM |
| Separation of mid/tweeter from woofer in rear speakers | dc | Multi-Way | 4 | 24th September 2002 11:44 PM |
| Page generated in 0.11557 seconds (67.07% PHP - 32.93% MySQL) with 10 queries |
