Old 19th May 2009, 03:24 PM   #21
Shaun is offline Shaun  South Africa
Shaun's Avatar
Originally posted by Helmuth
This i use with my behringer emc8000
I'd like to also share my mic circuit; very similar. I have gerber files for anyone who wants to build it.
http://www.elipse.co.za/Images/MicBehr.pdf
Shaun Onverwacht
|||||||||| DON'T PANIC ||||||||||
Old 19th May 2009, 09:26 PM   #22
DonA is offline DonA  United States
Like many here, I looked for a cheap solution to the problem of a reliable, accurate measurement mike. I was frustrated with small but still (to me) significant differences in results with different budget mikes. Eventually, I purchased an ACO Pacific PS9200/4012/7012 calibrated mike system. And you would think that would be the end of it, however, some observations eventually forced me to send the system out to be directly calibrated against not one, but two B&K calibration mikes and I am now absolutely convinced of the reliability and accuracy of my measurements. My whole purpose for relating this story is to show how difficult it can be to get 1 dB or tighter accuracy. However, as discussed above, with various budget mikes, you can still achieve USEFUL results above 2 to 3 kHz which will still serve you very well and will still be fairly accurate over a couple of dB. I think the cheapest way to accuracy is to find someone to calibrate your mike for you against a known reference. In this way, a budget mike can produce quite accurate measurements. Unless you have a friend to do it for you, expect to pay for it. I know everyone is looking for an easy and inexpensive answer. My solution cost me about US$2000 but I have absolute confidence in my measurements. Like an old friend once said... Buy the good stuff... It only hurts once... ;>)
One more thing... We haven't covered the issue of the reliability of distortion measurements and this may not be the thread to do it in, but there are MANY things to watch out for there before you can believe what you measure.
Old 20th May 2009, 09:36 AM   #23
ente is offline ente  Germany
Default Mic
... some stuff more:
http://www.fesb.hr/~mateljan/arta/Ap...r-Rev03Eng.pdf
and this (page 15 ff)
http://www.ctc-dr-weber.de/speaker/A...re%20First.pdf
Heinrich
Old 21st May 2009, 09:46 AM   #24
Default Panasonic wm-61a Calibration (Gain + Phase)
Hi, if of any interest I have a calibration file for the Panasonic wm-61a.
The capsules differ a few dB and degrees in phase.
But in overall they are quite the same
http://www.holmacoustics.com/downloa.../Mic_WM61A.cal
The attached image show 3 capsules (The dashed lines are the phase)
Old 21st May 2009, 01:35 PM   #25
infinia is offline infinia  United States
infinia's Avatar
Default Re: Panasonic wm-61a Calibration (Gain + Phase)
Hi
Yes, very interesting (for unit to unit variation) quite good, but expected from same/similar batches.
Any information of the test configuration would be very much appreciated? In other words ...Can it be repeated by DIY folks here?
TIA
like four million tons of hydrogen exploding on the sun
like the whisper of the termites building castles in the dust
Old 24th May 2009, 05:01 PM   #26
PLB is online now PLB  United Kingdom
Hi Thadman,
Sorry for the late response to this topic, but since I'm a relatively new member, I ran into problems with the attached file size and had to ask for help from one of the moderators.
I wanted to warn you about my findings on the Behringer ECM8000 that I recently purchased. I had checked out Behringer’s web site for the spec’s on this mic prior to purchase and it seemed OK. However, when I received it, I found the attached printed on the outer cardboard sleeve that covered the carrying case. As you can see, there is a significant rise in the response at low frequencies due to proximity effects, making it quite unusable as a measurement microphone at these frequencies. I haven’t had the chance yet to construct a phantom power supply for this mic, so I don’t know if this response truly represents the response of this particular ECM8000 sample. I’ve sent an email to Behringer about a week ago asking them to elaborate on the applicability of these curves to the ECM8000, but I haven’t received a reply yet. I’m hoping it isn’t going to be a problem, and that the response will be the same as what Behringer advertise on their web site. I will probably have a phantom power supply up and running in a week or so and will let you know my findings. If anybody else has checked for proximity effect on this microphone I’d appreciate them letting us all know their results.
Peter
Old 24th May 2009, 05:19 PM   #27
Shaun's Avatar
My guess would be that in order for the object to affect the mic response (proximity effect) it has to be of a size comparable to the wavelength at that frequency. Note also how quickly the effect drops away with distance.
This is just my opinion, of course.... the usual caveats apply.
Shaun Onverwacht
Old 24th May 2009, 06:48 PM   #28
Ron E is offline Ron E  United States
Ron E's Avatar
I wonder if that is a printing error.
"Proximity effect" is an issue with directional microphones. Omni mics should have no proximity effect.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan
Old 25th May 2009, 12:54 AM   #29
cuibono is offline cuibono  United States
cuibono's Avatar
Yeah, an omni mic doesn't have proximity effect - but that doesn't mean the Behringer doesn't have a bump in the low end. Anyone in the US should pay $40 for a calibration, its sooo worth it. See my post earlier in this thread.
Old 25th May 2009, 01:21 AM   #30
Thawach is offline Thawach  Thailand
Thawach's Avatar
cuibono, i think all mics to have proximity effect at low frequency. some mic has much proximity effect. some has less.
PC Dac Measurement supra Digital Line Level 1 14th July 2009 12:54 PM
non os measurement Bernhard Digital Source 3 13th September 2006 09:12 PM
how to take db measurement sonu Multi-Way 7 9th May 2005 03:03 PM
New measurement mic in UK pinkmouse Multi-Way 4 10th February 2005 05:46 AM
Page generated in 0.20336 seconds (54.54% PHP - 45.46% MySQL) with 11 queries
