Does anyone have enough insight to suggest how it might be possible to make a clone of this speaker ?
http://www.pmc-speakers.com/docs/145...b4df_DB1-C.pdf The claim is that this is a TL design in a bookshelf sized box ? (I have a pair of FB1's and they are really nice).
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig. |
#2 |
These are the Information I found across the net about the speakers:
Drivers: Vifa D27TG-30-06 and M13WG-08-09 Enclosure: see attachment |
#3 |
Inside pic
#4 |
I did a similar build here using similar drivers.
They sound good but I think they could have been as good (or better) with a simple ported box, avoiding some build and design complexity. The advantages of TL are realized with larger midbass drivers and boxes. |
#5 |
My first DIY speaker was a ported box:
My 'Moon-Onken' but it's a full-range, so the bass is limited. However, the real issue is that I find that the PMCs have a smoother response, I can listen to them for much longer without fatigue and they give up only a very little in the way of high end detail against the Onken's. Since my existing PMCs are a TL design I am wondering if this approach is partly responsible for the smoother sound, or if it is the drivers. I still have to try out some of the cone treatments recommended by Dave (planet10) to tame the high end a bit but I feel a new project coming on later this year involving a stereo amp design and a new pair of DIY speakers. Which direction to go for clean, smooth and decent low end ?
#6 |
frugal-phile(tm)
Here is a dimensioned drawing based on the pdf of post 2.
Perhaps someone with MJK could model the line (assumming that the drive ris a stock VIFA and not a custom OEM) dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#7 | |
frugal-phile(tm)
dave
#8 | |
The goal should be the best darn small-box DIY speaker ever made with a clean, smooth musical sound and enough bass to keep folks happy with the smaller box
#9 | |
I didn't find much about these drivers anywhere. Choosing drivers is another learning curve for me. For example, how would the PMC drivers compare with, say, the Peereless range ?
#10 |
My best guess is something very similar to:
http://www.tymphany.com/d27tg35-06 http://www.tymphany.com/m13sg-09-08 |
| F1 Clone DIY PCB | suds | Group Buys | 2 | 8th January 2009 09:50 AM |
| My F3 Clone | 04dgmsilv | Pass Labs | 11 | 31st August 2008 11:59 AM |
| clone AN/K | ccopp | Multi-Way | 0 | 9th July 2006 08:24 AM |
| Question regarding ProAc 2.5 Clone and Tempo 2 Clone | zoooh | Multi-Way | 5 | 11th March 2003 08:19 PM |
| Page generated in 0.12092 seconds (72.14% PHP - 27.86% MySQL) with 11 queries |
