Old 16th May 2009, 07:08 AM   #1
Default Sourcing Small High-End Coaxial
Hello Everyone,
I've long been attempting to source a 3" to 3 1/2" high end coaxial driver to meet the needs of my application, a new small satellite design. I've searched this a hundred times and believe I'm aware of most everything available, but I thought I'd put the question out to the board and see if there's something else to discover. Ideally, the unit should have a smaller, neodymium motor structure and very high end tweeter. Drivers with polymer tweeters typical of car audio would not be of interest. Thanks and looking forward to any new finds.
-Luca
Old 18th May 2009, 08:46 PM   #2
Andersonix's Avatar
Do you know about this Tang Band coax?
Tang Band W3-1723SA 3" Coaxial Midrange at Parts Express
I suppose the 4inch Vifa coax at Apex Jr is too big?
Old 18th May 2009, 09:22 PM   #3
Yes, I'm familiar with the TBs but not the Vifas. These are excellent suggestions! Others? If only the Vifas were a tad smaller, they might have been perfect. They must also work in a small sealed enclosure. The TBs have such a large magnet assembly, devouring internal volume.
Old 19th May 2009, 12:21 AM   #4
Andersonix's Avatar
Not all the TBs have a big magnet. This bamboo fiber TB looks like it has a decent top end, even accounting for TB's optimistic graphs. I'm saving up for it, as I had nice results with a W3-881S in a center channel.
Old 19th May 2009, 02:16 AM   #5
d to the g's Avatar
Have you contacted anyone at MISCO? Don't look at the stuff they have on their site, call up an engineer and tell them what you need. More than likely they do.
(i have no financial or personal stake in the performance of misco)
Old 19th May 2009, 03:36 AM   #6
Apex Jr is offline Apex Jr  United States
These coaxials measure at 3 7/8" and are concidered
at 4" ...
Steve at Apex Jr.
Old 19th May 2009, 02:11 PM   #7
Default Vifa 4 (or 3/78)
Steve,
It's these you're referring to, yes? I really can't change my parameters to fit 3 7/8ths, but it is so close, I may buy just for experimentation. How will they do in a sealed enclosure? Is that measurement to the outermost edges? Rare to find anything without holes drilled in the frame all ready, and that's a plus!
Thx -Luca
Old 19th May 2009, 02:11 PM   #8
d to the g -
I'm looking into MISCO. Many thanks. Great blog. -Luca
Old 22nd May 2009, 12:36 AM   #9
Pallas is offline Pallas  Pakistan
They might be too expensive, but you could source KEF's 3" Uni-Q drivers.
Old 22nd May 2009, 05:53 AM   #10
Why do you need a 3" coaxial? There are several drivers that size that will reach the tweeter range just fine such as the Fostex FF85K for example.
High performance DAC mDAC-2v(USB, Coaxial, Optical input) ck210 Vendor's Bazaar 4 6th July 2010 09:19 AM
high efficiency small sub sub_arctor Subwoofers 9 31st May 2007 11:38 AM
Small coaxial Karlson-couplers freddi Full Range 2 16th March 2007 07:06 PM
Small diy monitors - two way or coaxial? wxn Multi-Way 7 12th June 2006 02:56 PM
suspending a small tweeter in front of woofer for "coaxial" effect? bikehorn Multi-Way 3 2nd January 2006 02:04 PM
Page generated in 0.14687 seconds (63.06% PHP - 36.94% MySQL) with 11 queries
