while i am still waiting for my Kef 107 drive units to be rebuilt i was thinking of replacing the caps in the crossovers. There are 2 crossovers per speaker. Below are the original caps, values and overall quantity (all have tolarance of 10%) ALCAP 4.2uf 50 x 6 " 20uf 100v x2 " 40uf 100v x2 " 25uf 100v x2 " 300uf 25v x2 " 240uf 25v x6 " 50uf 100v x2 BENNIC BI-POLAR 10uf 100v x4 "100uf 50v x10 I suppose my first question is, do you think it is worth replacing all of them? And what with? Any help would be most appreciated. Thank you. |
#2 |
hello.
do you know how old are these caps? greetings......... |
#3 |
well the speakers are around 25 years old and i think they are the original caps. |
#4 |
they are really old........and perhaps a little bit dried out ( i presume these all are electrolytic caps; you must not change film/foil caps).
if you swap to new parts the sound will change a bit........perhaps you will listen first with the old caps .......... and change them part by part to the new ones............... there are many elco's with high values.do you have a schematic or so? nowadays elcos have a liittle bit different values,e.g. 22uf for 20uf,47uf for 50,........and so on.perhaps you will parallel some elcos to get these numbers. greetings............ |
#5 |
That's the real question; "with what" Those speakers were built in an era when quality was available. Your caps may well be quite usable. I would invest in a multimeter with a capacitance range and measure or perform a frequency sweep over the crossover frequencies first.
I've been looking for caps for a new amp. What I've found so far has a life expectancy of 2000 hours. But that keeps me employed Regards |
#6 |
Hi and thanks for the replies.
Yes, i think i may well test the caps porperly first as i wouldn't want to replace them if i can't get exact value replacements. Will let you know what i find. Thank you. |
| KEF 107/2 crossover replacement | LaPlantey | Multi-Way | 3 | 6th December 2007 06:09 AM |
| Replacement caps | reddish75 | Solid State | 15 | 17th February 2007 03:58 PM |
| Bypass caps on crossover caps... :D | quickshift | Multi-Way | 19 | 27th November 2005 12:59 PM |
| Replacement Caps for a SSL Console? | moamps | Parts | 0 | 12th February 2005 05:02 PM |
| replacement tweeter caps | Dave Jones | Multi-Way | 2 | 27th August 2003 06:14 PM |
| Page generated in 0.19435 seconds (32.98% PHP - 67.02% MySQL) with 10 queries |
