Tweeter damping resistor. Why?
Old 15th May 2009, 02:55 PM   #1
zebra100 is offline zebra100  United Kingdom
Question Tweeter damping resistor. Why?
What is the purpose of adding a largish value of resistor in parallel with the tweeter coil? Is it just for current limiting, and can it safely be done away with?
Old 15th May 2009, 03:17 PM   #2
to provide a more resistive and predictable load for the crossover and thus better define the roll off frequency and roll off slope.
It can also reduce the apparent sensitivity of the treble driver in comparison to the bass/mid driver.
A cross over that is loaded with a frequency variable load, does not achieve the theoretical slope and frequency predicted by the R & L & C values used in the crossover.
regards Andrew T.
Old 15th May 2009, 04:47 PM   #3
Thanks Andrew,
Can it safely be removed without fear of damaging the tweeter?
Chris.
Old 15th May 2009, 05:03 PM   #4
without seeing the crossover, it's impossible to offer a guarantee, but I suspect no damage will occur.
However, it's removal will completely alter the frequency response of the speaker. All the other components will need to be re-selected to try to bring back the response and may never sound as good again.
regards Andrew T.
Old 15th May 2009, 07:46 PM   #5
Pano is online now Pano  United States
Pano's Avatar
I'm with Andrew on this one. Best to leave it in place. Removing it will cahnge how the high pass filter works and may do things you won't like.
If you do try, turn it up slowly.
Take the Speaker Voltage Test!
Old 15th May 2009, 09:11 PM   #6
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
No can do, for the reasons Andrew pointed out.
planet10 needs your help:
Let's help Ruth and Dave
Old 15th May 2009, 09:36 PM   #7
I haven't heard it yet. I'm in the process of building it. I was given the design by someone else. I think I will leave it in the design.
Old 16th May 2009, 01:09 AM   #8
PeteMcK is offline PeteMcK
there are 2 ways to pad down a tweeter - the standard way is to use a L-pad i.e. a resistor in series with the tweeter and another in parallel - as noted above, this keeps the impedance constant for the crossover.
another way is to use a single resistor in series, but if this is tweaked, freq response of the xover will change because of the changing impedance. To avoid this, the resistor can be placed before the crossover components.
This calculator will show you how it works:
http://www.sengpielaudio.com/calculator-Lpad.htm
This page may be help you with how xovers work:
http://sound.westhost.com/lr-passive.htm
Impedance varies with frequency, use impedance plots of your drivers and make crossover calculations using the actual impedance of the driver at the crossover frequency
Old 16th May 2009, 11:59 PM   #9
fatmarley is offline fatmarley  England
Just found this thread: Click here!
Old 17th May 2009, 11:43 PM   #10
if you're using a non-ferrofluid damped tweeter, then use the L pad method, otherwise either method is OK.
The reason the guys in the linked thread had problems is because they're using voodoo rather than appropriatly calculated crossovers for the job - crossovers are neither good nor evil, they're just a tool to get a job done...
Tweeter damping resistor. Why?Hide this!Advertise here!
Peavey Tweeter Resistor jdm01 Parts 4 29th March 2013 11:30 PM
dynaudio crossover - value of tweeter resistor? adamt Multi-Way 3 23rd January 2007 11:49 PM
piezo tweeter resistor UNDERSTANDIN Multi-Way 4 23rd September 2005 08:37 AM
Tweeter damping? graks Multi-Way 5 28th May 2005 07:40 PM
Which value resistor to use with piezo tweeter Bull Multi-Way 0 14th January 2003 09:56 PM
