Series or parallel capacitor for bass X-over
Old 15th May 2009, 08:05 AM   #1
zebra100 is offline zebra100  United Kingdom
Question Series or parallel capacitor for bass X-over
Aside from the obvious change in crossover point, what are the advantages/disadvantages of having a capacitor either in series with the inductor or in parallel with the load (Bass driver)?
The figures I am getting are about 400Hz crossover with a 5mH coil and a 150uF cap in series into an 8ohm load, as opposed to 250Hz with the cap in parallel with the load.
Many thank's,
Chris.
Old 15th May 2009, 08:27 AM   #2
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
With cap placed correctly in paralel it lowers impedance/lessens the rise, making the inductor work more effectively
Cap placed in series will form a 1.order highpass, taking away the low bass
In your situation it will probably dampen bass
sometimes we know very little, and sometimes we know too much
Old 15th May 2009, 08:43 AM   #3
Thankyou,
Parallel it is then .
Series or parallel capacitor for bass X-overHide this!Advertise here!
What would you do? series/parallel MtnBob Multi-Way 22 23rd August 2016 01:41 AM
Three 10" 4Ohm subs, wired in series or series-parallel? Nagamitsu Car Audio 38 19th February 2014 11:16 PM
series or parallel? medicman Tubes / Valves 5 22nd January 2009 04:42 PM
capacitor in series with pot, no bass. kmj Chip Amps 2 29th March 2005 11:28 AM
Copyright ©1999-2017 diyAudio
