Old 14th May 2009, 12:42 PM   #1
xpert is offline xpert  Afghanistan
Account Disabled
Question negative acoustical feedback, anybody?
Once I tried to apply feedback to a bass speaker via microphone sensor. It worked to some degree.
One shortcoming was the marginal bandwith in which it was useful. Going to high in frequency negative feedback evolved to positive FB (resonance ;-) due to phase shifts due to coil inductance at most.
Second shortcoming was the confinement in closed boxes due to low frequency phase shift > 180° with reflex. Seconded to some extend by the challenge to summ up cone/pipe parts.
By now I use much bigger and more costly drivers than then. A feedback system would not contribute to much to the total cost. I discovered that the higher harmonics won't be to much of an issue with a decent driver due to masking by human hearing. But subharmonic components would matter - perhaps. And further on I've got an idea how to sneek around that phase issues with reflex. In the end I would like to take a new chance.
Anybody to share experiences with? Since that all ain't rocket science I won't worry to much about patents and such. On the other hand I won't discuss things like "feedback always comes to late" the 1001th time again.
Comments appreciated
Old 14th May 2009, 01:04 PM   #2
bear's Avatar
Generally speaking you are talking about what is commonly called "servo control".
There are a number of means of detecting the motion of the cone. A microphone is one. It needs to be very close to the cone in order to work well. Others include accelerometers, light pick-ups and inductive pick ups. The dual voicecoil is part of that.
All of them have to deal with the same phase shift issue that you noticed.
So, generally speaking most feedback schemes confine themselves to a narrow range, usually for Bass and Sub-Bass to avoid the phaseshift problem.
You might want to search here and online and look at the various servo-control projects, methods and patents...
_-_-bear
_-_-bear
http://www.bearlabs.com ...ur feeback please - like/dislike my what I have written? PM/email tnx. --
Negative Feedback? Binaural Tubes / Valves 15 12th March 2009 07:05 PM
Negative Feedback AmpBuilder225 Tubes / Valves 7 20th February 2009 08:05 PM
Less Negative Feedback Is Better? CarlosT Chip Amps 25 14th December 2006 10:18 PM
Get away from negative feedback ? N-Well Pass Labs 3 1st March 2006 10:17 PM
Negative Feedback Jack Thomas Tubes / Valves 6 5th May 2003 12:38 AM
Page generated in 0.10801 seconds (55.35% PHP - 44.65% MySQL) with 10 queries
