How do you think of the cabinet?
Cabinet size: 1680mm (H) x 250mm(W) x 320mm(D) woofer: 8 inch x 2 pieces mid: Seas H1304 X 2 pieces tweeter: Fountek NEO CD3.5H |
#2 |
photo 2
#3 |
The 8 inch kelvar woofer T/S parameter (used LMS for measurement).
Fo: 30.4576 Hz Zmax: 97.2938 ohm Sd: 0.0216 sqM BL: 13.4758 TM SPL: 85.8776 dB Qms: 5.2119 Qes: 0.3731 Qts: 0.3482 Vas: 33.2111 Liter Cms: 501.2736 uM/N Mms: 54.4718 g Mmd: 52.6465 g Levc: 1.0128 mH Rem 8.1688 @1kHz Levc: 0.1465 mH Rem 38.5210 @ 20kHz Krm: 88.2776 m ohm Erm: 0.5177 Kxm: 286.0775 mH Exm: 0.3547 the woofer cabinet volume is 26 Liter, Fb is 35Hz. |
#4 |
the woofer was designed and made by myself since the good woofer are expensive.
#5 |
The kelvar cone.
#6 |
Very nice cabinet indeed! And an impressive looking woofer.
Surely there was a higher cost of designing and manufacturing your own woofer, than purchasing one?
The power of Science compels you! |
#7 |
the magnet size: 120mm x 60mm x 20mm
the plate thickness: 8mm the voice coile winding length: 19mm |
#8 |
the Magnetic Circuit parts
#9 |
Hi DcibeL, I only made 6 pieces.
| 8'' woofer for 20 litre cabinet | fin1bxn | Multi-Way | 5 | 17th April 2007 04:05 PM |
| Woofer choice in 2-way sealed cabinet | tinos5601 | Multi-Way | 1 | 13th March 2007 04:55 AM |
| Random 12" woofer in 100 liter cabinet | Klimon | Subwoofers | 4 | 20th December 2006 03:16 PM |
| Suggestions on stiffening woofer cabinet? | Keith TDI | Multi-Way | 4 | 17th March 2002 06:33 PM |
| Page generated in 0.11543 seconds (66.82% PHP - 33.18% MySQL) with 11 queries |
