The secret of building a good 2-way
Old 10th May 2012, 01:58 PM   #191
Starre is offline Starre  Sweden
I have no reason to stop you, hehe, go ahead.
Old 29th March 2014, 12:57 PM   #192
presbel is offline presbel  Philippines
Send a message via Yahoo to presbel
For Salas:
Can I use Seas CA22RNX instead of the CA22RNY? For tweeter Peerless HDS tweeter I think is not available is there a substitute for this?
Old 24th April 2017, 04:51 PM   #193
critofur is offline critofur  United States
critofur's Avatar
Send a message via AIM to critofur Send a message via MSN to critofur Send a message via Yahoo to critofur
Originally Posted by presbel View Post
For Salas:
The "Peerless HDS" has been replaced with a new name (but same tweeter):
ScanSpeak Discovery D2608/9130 1" Textile Dome HDS Tweeter
Critofur
http://www.ohmspeakers.com <- all the folks here are my friends
Old 29th December 2017, 12:30 PM   #194
frankmalz is offline frankmalz  Germany
Default Salas 2way in wider enclosure
i would like to build the Salas 2way speaker -but in an Audio Note E enclosure.
It is a little smaller in the deep- to achieve 45l.
Which crossover parts need an adjustment?
Is it possible only to lower the value of the L1 coil?
Old 29th December 2017, 12:41 PM   #195
Default Something from the german Klang&Ton with Ca22rny
Ca22rny with wide baffle
Old 29th December 2017, 01:06 PM   #196
foreveryoung is offline foreveryoung  Viet Nam
Originally Posted by planet10 View Post
In 40 years of building speakers the best 2-way i've done is Tysen... active XO (PLLXO @ 333Hz) SDX8 sealed, FF85KeN in midTL.
dave
Just curious, so for this setup, you use an active XO, Tysen driver as bass and FF85KeN as Mid & Trebe? Sealed?
Old 29th December 2017, 02:03 PM   #197
globalplayer is offline globalplayer  Germany
globalplayer's Avatar
The secret is using a good fullrange.
Old 29th December 2017, 04:08 PM   #198
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Surely playing with L1's value is of primary concern because different baffle width will mostly change the curve in the lower mid and upper bass regions. It may be enough.
But box dimensions changing can bring smaller ripple effects higher up in frequency also. Best is to measure raw response and impedance of drivers on the new cabinet first.
When not equipped for such measurements, modeling with a diffraction simulator to mix published responses with calculated acoustic effects in a crossover simulator is recommended.
So to anticipate possible filter components value adjustments before migrating the design. Like with using those excellent software contributions from Jeff Bagby and Bill Waslo:
Jeff Bagby's Software Page
XSim free crossover designer
Old 29th December 2017, 06:51 PM   #199
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Yes. We have now developed Tysen V2 with drivers you can get. FF85wKeN + a pair of Silver Flute W14eN loaded push-push in an ML-TL. Can be biamped and we have developed a passive XO. This is our budget WAW (aka FAST)
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 30th December 2017, 03:15 PM   #200
Thank you very much Salas- i will try your suggestions.
Best wishes
Frank
The secret of building a good 2-wayHide this!Advertise here!
The secret janey peranders The Lounge 1 30th January 2006 09:09 AM
Building good stereo speakers Godfather7 Multi-Way 8 16th September 2005 08:08 PM
What's the secret? lumanauw Pass Labs 23 31st March 2005 04:11 AM
Good book on Speaker Building? pixie Multi-Way 14 30th May 2004 01:02 AM
good driver for speaker building sma Multi-Way 4 24th January 2004 08:44 AM
