Non-forward-firing Woofers - Page 2 - diyAudio
Old 14th December 2001, 04:28 PM   #11
Eric is offline Eric  United States
Eric's Avatar
Be sure to read the <a href="http://www.adireaudio.com/Tech%20Papers/driver_orientation.htm">Shiva White Paper</a> on down vs. front firing for woofers. It provides calculations that you can perform to see if a particular woofer is suited for horizontal mounting.
Old 14th December 2001, 04:49 PM   #12
Won is offline Won
Well, that was never really the question; I know that the Adire Tempest is suitable for horizontal mounting because the reference designs are downard-firing. I was wondering what the relative merits of the horizontal versus vertical alignments were.
-Won
Old 14th December 2001, 05:17 PM   #13
Eric's Avatar
Won: I realize that this was not exactly your question, but wanted to be sure you knew that not all drivers like to be mounted horizontally...
I don't want to see you (or anyone else here) spend a great deal of time and money on a project and then have problems with it!
Old 14th December 2001, 06:01 PM   #14
jdh is offline jdh  United States
Being an engineer also, I understand, but audio is 50% science and 50% art. That's where the 'warm fuzzies', 'slam', 'punch', 'presence', etc. etc. come in. I do have a couple of comments, tho.
Downup-firing woofers do have the drawbacks as mentioned before (cone sag; dampening factor: discussed later). Cone sag will shorten the life expectancy of the driver over side-firing design, simply by the fact that you can rotate the side-firing driver every couple of years to extend driver life. Facing the driver directly into carpet will cause significant output loss. Most down firing systems use a reflector base for wave propogation. Care should be taken in the design allow enough distance between the reflector base and the woofer to prevent loading of the driver (as GRollins stated). A connical shaped reflector base would be best for wave propagation, but construction is far more difficult depending on your construction skills and access to tooling.
I do have some thoughts on side firing woofers. GRollins stated that side firing woofer could keep the frontal width smaller and is obviously true. The performance suffers as the proximity of the two sides increases, requiring more sophisticated defraction baffling within the enclosure (such as BMW's matrix system) to prevent rear woofer loading. This is where deeper is better.
I would like to address David Thatcher's statement about the loss of 'punch' (the artsy term) in a down firing sub. True, this is not a very scientific descriptioin, but if you think about the musical spectrum, it might give this simple terminology a little more credibility. Take the hit on a timpani drum for example. This contains both very low frequency (worble) and higher resonances (the 'slam' of the skin giving definition or liviliness to the sound). Because of the inherent damepening of higher frequencies (As Kiwi-abroad stated), steming from loss through reflection from the base, some of this 'slam' of the drum is lost. This assumes, of course, a xover point above where this is prevelant. Careful xing over at a lower frequency (60-80Hz-which I think is better for this design) then puts this 'slam' within the mid-woofers realm, requiring consideration of using a large enough cone size to produce the 'slam' factor. This is where side-firing is better giving the 'slam' back to the woofer while xing over at a higher point (80-100 Hz).
Just my take on things.
Jeff
Old 14th December 2001, 09:07 PM   #15
JoeBob is offline JoeBob  Canada
JoeBob's Avatar
I too am planning on making a sub from the adire tempest (once I finish my xovers for my main speakers). And including it in a coffee table is what I'd like. Everyone talks about down and side firing positions, what about top firing? I was thinking of having it top firing (if it's even possible) with a gap between the sub enclosure and the coffee table top, and have a hole in the coffee talbe top filled with plexiglass or glass, so that from the top the driver is viewable, but isn't open to damage or completely covered by the top (as I said there'd be a gap).
Old 14th December 2001, 11:48 PM   #16
JoeBob,
You be a sick puppy!
I kinda like that idea, in an over-the-top sort of way.
Just don't put Aunt Gertrude's irreplaceable Ming vase on the coffee table, okay?
(I'd go for at least 3/4" plate glass, or 1" Lucite if you do it.)
Grey
Old 15th December 2001, 01:28 AM   #17
JoeBob's Avatar
Ya, the coffee table wouldn't hold anything breakable obviously. And if it is indeed possible I will surely do it.
Old 17th December 2001, 01:57 AM   #18
Bill Fitzpatrick's Avatar
THE SAGGING PROBLEM
Just because it doesn't sag at first is no indication of what might happen down the road. I built one set of down firing woofers for someone and everything is fine at first - 2 years later the cones had sagged so much that the woofers were for all practical purpose acting a rectifiers. Not good. Gravity will always take its toll.
The best solution for coffee table use is to have one woofer downfiring onto a panel, one woofer upfiring onto a panel. The enclosure is vertically symmetrical. Every few months, flip it over!
The panels? Absolutely rigid, no flexing.
THE COFFEE TABLE PROBLEM
But, the coffee table idea is no good in the first place because of the exaggerated time alignment/phase problem! The woofers belong at the same listening distance as the satellites. This really is not negotiable. Else, why bother with a phase coherrant crossover like the L/R for the woofer to mid? And, on top of that there is the . . . .
THE SLOT LOADED WOOFER PROBLEM
Which is what downfiring woofers are. Qts changes plus there is a resonant cavity in front of the woofer. This must be accounted for in the overall design of the system. A down firing woofer acts much like a band-pass box and if you don't know what you are doing, it's a poorly designed bandpass box.
PUNCH (or whatever you wish to call it)
This is not soley the domain of the woofer. You will get maximum punch if the system is phase coherrent, has a flat frequency response at the listening position and the speakers and listener are properly positioned in the room so as to minimize the standing wave and early reflection problems. It's as simple as that. Square wave reproduction AT THE LISTENING POSITION in the first 30ms is what you are looking for. There are magic words here; SQUARE WAVE. Repeat after me, SQUARE WAVE, SQUARE WAVE. This is a concept that seems to be ignored. Square wave reproduction is a valid criteria.
SIDE FIRING WOOFERS
No problem and no big deal. It's OK up to about 200 or 300Hz with normal sized woofers. It's pretty much related to dispersion.
At the "listening positon". A key phrase. And the listening position isn't very big either. In fact, if you take EVERY single thing into consideration, the listening position is probably no bigger than a 2 foot diameter circle. Get things perfect for this circle and everything outside starts to fall apart. Try to expand this circle and everything inside it starts to fall apart.
You can't have everything.
Old 22nd December 2001, 01:21 PM   #19
[QUOTE]Originally posted by Bill Fitzpatrick
[B]THE SAGGING PROBLEM
How high should the woofer be from the ground to avoid this problem?
Thanks,
Dave
Old 22nd December 2001, 03:30 PM   #20
My efforts in this area used a 2"x2" leg at each corner of the baffle board. The legs were usually about 9" long. This reduced the cavity effect to pretty much of a non-problem and the Q change was somewhere in the area of 5%, if I remember correctly - it's been a long time - 1970.
One thing I do remember quite vividly was that a 150 pound coffee table with 4 downfiring 12" woofers actually raised itself off the floor by a good 2" on a particularly loud bass note!
It certainly would be easy enough to build a box with interchangable legs and run some tests outdoors.
Front firing vs down firing sub? alex_g Subwoofers 32 22nd June 2010 12:34 PM
Down firing vs side firing? Tee-Bruce Subwoofers 36 26th August 2009 06:32 AM
Woofer: side firing pair vs front firing? tcpip Multi-Way 13 9th September 2005 02:13 PM
Side firing woofers in 3-way Mos Fetish Multi-Way 7 3rd August 2003 01:57 PM
side firing woofers ogp Multi-Way 2 9th January 2002 01:44 AM
Copyright 1999-2017 diyAudio
