Non-forward-firing Woofers
Old 22nd December 2001, 07:01 PM   #21
kelticwizard is offline kelticwizard  United States
Wizard of Kelts
diyAudio Moderator Emeritus
Won:
The NHT 3.3 has a side firing woofer and crosses over at 100 Hz.
Looking at a Vifa 8" response chart-half your diameter-60 degrees off axis seems to be an issue even at 500 Hz.
Considering where the NHT crosses over with it's 12 inch, and the fact that you want dispersion of over 90 degrees, I would recommend keeping the crossover for a side firing Tempest under 100 Hz.
Non-forward-firing WoofersHide this!Advertise here!
Front firing vs down firing sub? alex_g Subwoofers 32 22nd June 2010 12:34 PM
Down firing vs side firing? Tee-Bruce Subwoofers 36 26th August 2009 06:32 AM
Woofer: side firing pair vs front firing? tcpip Multi-Way 13 9th September 2005 02:13 PM
Side firing woofers in 3-way Mos Fetish Multi-Way 7 3rd August 2003 01:57 PM
side firing woofers ogp Multi-Way 2 9th January 2002 01:44 AM
Copyright ©1999-2017 diyAudio
