Old 12th May 2009, 12:07 AM   #1
Mach5 is offline Mach5  United States
Default Drive from crossover?
I'm working on a new 3way speaker from a scratch design. Eventually I'd like this to a an active system. Right now I'm using a crown stereo amp for power and crossover(digital) duties so I can adjust more easily. The issue is that finding a tri-amp suitable for active mounting is difficult, much less finding a good one(and $$$!!). I could build a 3way tube amp for, which would be kinda cool. But this will get in the way of developing the speaker for a couple of months I'm guessing.
So the question is this. Since my speaker has about a 105~110db sensitivity can I just drive it directly from a DSP crossover at line levels? Only temporarily until I can afford to do proper amps of course
Someone told me line level is about 2V in general but what's the wattage? 1/3watt should be fine right?
also, any thoughts on the resistance loads a digital crossover is intended to drive vs. a speakers's load
Old 12th May 2009, 12:42 AM   #2
tinitus is offline tinitus  Europe
Default Re: Drive from crossover?
Ehhh, how
Old 12th May 2009, 01:26 AM   #3
btw, google "41hz audio amp kits"
They have several small and cheap amp modules that might suit your needs
Old 12th May 2009, 01:41 AM   #4
Mr Evil is offline Mr Evil  United Kingdom
An op-amp, as might be used for a line-level output, will typically have a maximum output current of around 20mA. This is woefully inadequate to drive a speaker. You will at best get a quiet, but horribly distorted output, and at worst you will fry something.
https://mrevil.asvachin.eu/
Old 12th May 2009, 06:33 AM   #5
forr is offline forr  France
forr's Avatar
Hi Mach5,
Some guys in France - I think one of them is JM Le Cleac'h - have loaded the output of a DCX Bheringer with horns through an elevating transformer. As JM is writing on this forum, you could ask him more details.
Old 12th May 2009, 07:34 AM   #6
Default Re: Re: Drive from crossover?
Originally posted by tinitus
Ehhh, how
Crown xti 2000 has a built in DSP
It's not the ideal hifi amp though and a bit bulky to mount to the speaker and it's only stereo.
Old 12th May 2009, 07:48 AM   #7
Originally posted by forr
Hi Mach5,
Hmm, calling lecleach and all French experimenters to release the secret and free music from amps once and for all
CrossOver for Mini AutoGraph Single Drive hllchan Multi-Way 1 27th July 2009 04:00 AM
FS: Hitachi Router and Terk outdoor HD antenna, BD-Rom drive, Xbox HD Drive and more. Dougie085 Swap Meet 0 3rd May 2008 07:31 PM
mix current drive with voltage drive at LF? capslock Multi-Way 0 27th April 2006 10:17 AM
Idler wheel drive vs. Belt-drive mig-ru Analogue Source 4 3rd December 2003 12:06 AM
Computer Question-Any Problems Transferring Office 97 From D Drive to C Drive kelticwizard Everything Else 12 22nd January 2003 03:34 AM
Page generated in 0.09927 seconds (77.57% PHP - 22.43% MySQL) with 10 queries
