Old 27th April 2003, 09:20 PM   #1
Talking Help for new design
As it is, i'm currently listening to a diy monitor using the scanspeak 18w8546 and the scsan speak 9700 tweeter.
I want new speakers!
After many hours of browsing, looking around, and doing some calculations (Loadspeaker design cookbook 5th ed.) i've reached some conclusions:
1. I want to use my old scanspeaks - all of them. I would like to add one 18w8546 each side - MTM array. Each unit in a 10 litre closed box (calculations showed this volume for a Q=0,6).
2. I would like to add two 21w8555-01 per side. Each of these in a closed box around 35 liters (Q=0,6).
What i Need:
1.Please check my calculations...
2. Crossover design - would like to go 3 way...
3. comments.
4. Anyone know how much deeper the scanspeak 9700 tweeter should be mounted in comparison with the 18w8546?
I've attached an unfinished .fig file containing the ideas i have for this speaker...
Jacob
Old 28th April 2003, 04:02 PM   #2
Taco is offline Taco  Netherlands
Check this speaker for mounting the 9700. This speaker also uses the 21w8555.
http://members.home.nl/edgar.beers/eveII.htm
Collated Design Criteria/dimensions for Ariel ML-TL Design talsius Full Range 1 13th October 2011 05:28 AM
Wilson Watt Puppy Clone Design - Design Review Please soundengine355 Multi-Way 8 15th August 2008 02:07 PM
4th order bandpass, wheel well design :) (design inside) TWOJZ Car Audio 28 13th January 2008 02:56 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
