Yes I searched, and no this isn't just an mdf versus plywood debate. I'm only concerned about resonances under 1khz, maybe even a bit lower. For example I have a three way where the mid is a dome with its own enclosure. So only the woofer running up to about 800hz would actually excite panel resonances.
Given that which is better? I figure ply being stiffer and light would have higher Q, higher frequency resonances, while mdf would be lower Q, but also lower in frequency. Is the ply resonance high enough to be out of the woofer's passband? |
#2 |
frugal-phile(tm)
Ply is stiffer, lighter, and better damped. Energy to excite a resonance is inversly proportional to frequency. Higher Q resonances also reduce the available energy to excite reasonances.
For really low frequencies, one is also interested in keeping the box from ballooning. Stiffer is good here. Further, in a woofer, a significant amount of the box load can be actively cancelled with a push-push arrangement of woofers. dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
| CD With dodgy low frequencies ... | mart34 | Multi-Way | 5 | 12th July 2009 04:01 AM |
| Best car amp frequencies? | Flyin11 | Car Audio | 11 | 5th January 2008 02:36 AM |
| Lower rails for lower impedance? | 95Honda | Solid State | 7 | 19th December 2007 08:59 AM |
| Lower frequencies with ported boxes. | Arx | Multi-Way | 21 | 4th July 2007 04:32 AM |
| Frequencies for EQ? | Lisandro_P | Solid State | 5 | 12th November 2001 07:16 AM |
| Page generated in 0.06025 seconds (75.85% PHP - 24.15% MySQL) with 10 queries |
