#21 |
Here are the schematics for the Thor crossovers. These are the redesigned and updated ones from Jimangie1973.
#22 | |
My suggestion is the DTQWT from Troels. http://www.troelsgravesen.dk/JA8008_DTQWT.htm and even cabinet construction is pretty simple: http://www.troelsgravesen.dk/JA8008_DTQWT_cabs.htm I think this rendition TQWT, (though it does not include the 2 10" drivers of the DTQW, but could easily), represents the best aesthetic: http://www.troelsgravesen.dk/JA8008_Liudas.htm (..I'm not fond of Troel's vertical wood inlay "pinstipes" down the front, so Liudas's looks better to me - more monolithic.) IMO it's a design that can be used for Music and HT (with a good off-axis horizontal response). The cabinet height is about right as well. It's also a design that really doesn't need "up-grading" - ever, (except perhaps for improving crossover components to the ultra expensive Dueland CAST stuff at a much latter time.) Furthermore, it's capable of being driven by a much greater variety of audio equipment - specifically lower powered tube amps should you wish to explore that potential "avenue" at some point. It is expensive, but it isn't abhorrently so. The Eminence 10" woofers can be had from Blue Aran. But whatever you end up with, I wish you luck!
perspective is everything |
#23 |
Hello all,
Just a couple more questions if someone could help. I have narrowed the choice to just 2. OPTION 1: Seas Thor (small thor, using Jimangie1973 XO provided by Mattmcl... Thanks!) http://www.diyaudio.com/forums/showt...25#post1781925 Drivers: W18E001 (woofer) T25CF002 Millenium (tweeter) OPTION 2: Zaph Audio ZRT (2.5 way) (ScanSpeak) http://www.zaphaudio.com/ZRT.html Drivers: 18W8531G Revelator (woofer) 6600 AirCirc (tweeter) Could anyony possibly comment on the potential weeknesses/strengths of either of these systems incomparison to each other? I'm kind of leaning towards option 2 at the moment (for no other reason than it is my first build and might be a bit easier to get right). The only problem is that I am finding it difficult to find a 6600 AirCirc in the UK. If I cant get one, I'm assuming that an alternative will require a tweeked crossover design (which is beyond me at the moment!)? Unless anyone can advise on an alternative, I was thinking about replacing the 6600 AirCirc: http://www.tymphany.com/d3004_660000 With this (R2904/700009): http://www.tymphany.com/r2904_700009 Would this present me with any problems? Many many thanks for your patience!!! |
#24 | |
Do you want to spoil the recipe... An EGO tweeter. You want a Mercedes but you don't know how it works?!
#25 | |
Please be aware that I know very little about DIY and I am hopeful you can understand that we all have to start somewhere. I do'nt know what any of these DIY projects sound like. If there are items that are to be considered 'off topic' please could you advise so I can avoid annoying anyone? Like I said, I could'nt find the originally spec tweeter so was looking for an alternative. Have since learnt that it does'nt work like this but thanks all the same. |
| Start a SOZ | Jean-Paul_2 | Pass Labs | 21 | 21st June 2009 03:46 PM |
| Will start my new Gainclone from Start, Need Help | samsagaz | Chip Amps | 4 | 27th May 2008 09:39 AM |
| Not being able to post replies on any post on Parts & Supplies | Mayank | Forum Problems | 0 | 8th June 2007 02:38 PM |
| A guiding Post for helping any Newbie to start.. | deepanger | Solid State | 0 | 11th December 2002 10:01 PM |
| Page generated in 0.09529 seconds (78.00% PHP - 22.00% MySQL) with 11 queries |
