Hi members,
I put together an active xover based on opamps. It's based on a Sallen/ Key circuit with a slope of 24dB. Also there's a notch arround 30Hz. I intend to use it with my Apogee Duetta (magnetostatic 2way planar). The Notch should cure a big panel-resonance in the bass-foil. When I simulate it in LTSpice I see a phase shift from 0- to 360 degrees. Like the attached pic. This puzzles me a bit, 'cause I read that this kind of circuit is phase coharent (?right word?). In my understandings, ideal phase diagram should be a strait line (theoreticaly). Can I expect instabilities in reproduction of space (placement of singers, instruments, etc). Or is this shift ignorable? If yes, are there ways to flatten the phase-shifting? Thanks for your input. |
#2 | ||||
First order speakers have measurably different power response and distortion. The mid-range drivers used need to be resonance free as opposed to resonance supressed. Some people probably prefer those characteristics. Quote:
#3 |
OK, thank you Drew.
| Ushers 8848P's phase plug....know where to Xover? | License2ILL | Multi-Way | 19 | 23rd December 2007 02:19 PM |
| Active XOVER....OPAMP or discrete....??? | Lyra | Multi-Way | 8 | 23rd March 2007 12:19 AM |
| Circuit for variable phase 0-180 control for active L/R xover | georgehifi | Solid State | 4 | 20th September 2006 09:55 AM |
| LR xover question | steverb | Multi-Way | 12 | 20th April 2004 09:12 PM |
| Opamp phase shift - open and closed loop. | Circlotron | Analogue Source | 8 | 23rd April 2003 07:06 AM |
| Page generated in 0.08482 seconds (72.05% PHP - 27.95% MySQL) with 11 queries |
