I have been using a pair of piezo tweeters in my system since the 1970s and one has recently gone open-circuit after the chip amp that was driving it went DC. I have attemped a repair but it doesn't sound so good now.I am looking for a replacement, but these seem to be hard to find. The tweeter is a direct-radiating piezo with a metal chassis instead of the usual plastic one, and I think they were used in some early Celef and ProAc speakers. They are about 3.25 inches in diameter. When I bought them, they were marketed by Bandridge but I suspect that they were made by Motorola. If anyone knows where I can get one of these, or any other info about them please let me know. I hope I have successfully attached an image... Keith |
#2 |
Keith,
Motorola sold their Piezo division some time ago. It has been through a number of different hands. It is now owned by Piezo Source. Iain |
#3 |
martinsoundpro.com is selling piezos (not the cheap junk sold at partsexpress).
http://www.martinsoundpro.com/item.asp here is another source. http://www.adelcom.net/MotorolaTweeters1.htm The 1016a is nice but can't be run passively without a transformer network. I've had great luck running a piezo with an active crossover (the ones that ring at 4.5khz, I run 60 ohm in series and active cross it at 5khz LR so it is 6db down at 5khz). Norman |
#4 |
Thanks Iain and Norman,
I have checked all three websites and none of them list one like mine. I think I will contact Piezosource though to see if they have any info. Keith |
#5 |
yup, I doubt you will find it.
I'm now quite discouraged finding amps and receivers that sound wonderfull, but are now 20-30 years old. They cost little but falling apart and will need switchs / caps, etc. But they are 1/10th retail and nothing sounds as good unless it is the cost of a 2 year old car. Speakers are a worse gamble. Norman |
#6 |
Hi Keith,
It's a pity that you don't have the reference for your tweeter. Wayne P. from Pi Speakers, used to have a model of a speaker (kit) with a piezo (KSN1038 http://www.audioroundtable.com/PiSpe...ges/16150.html ). In the mean time some years ago he did the upgrade of the kit with a new tweeter that you could buy from him. Now I don't know what he is using anymore (I looked and is a DX25), but you sure can give a look for yourself and ask him in the forum or by mail. He also sells the xover (cap) to go with. What's the sensitivity of your speaker(s)? http://www.pispeakers.com/Products.html |
#7 |
Thanks,
There are some interesting discussions on piezos in that forum. It seems the KSN1038 is a horn unit though. I have found out that the KSN1036 is a similar-sized direct-radiating piezo but it has different contruction (plastic case, grille on front etc). I'll keep looking... Cheers |
#8 |
I'm still searching, but in the mean time, I have put together a picture of all of the different Motorola piezos that I have found, along with their part numbers. This may be of use to someone other than me
Here is the pic... |
#9 |
I'm still searching. Surely somebody must know something about these elusive tweeters? Even a model number would help.
I have got hold of a ksn1036 and it is quite different to mine. I'll do some careful listening and perhaps some measurements to see if they are compatible. Keith |
#10 |
why not give up and get a modern pair of compression drivers and waveguides? Check out the earl geddes threads.
col.
http://www.minirig.org.au |
| Piezo Tweeter for Dogs | Gold_xyz | Multi-Way | 80 | 15th October 2011 10:59 PM |
| Piezo tweeter to my BIB? | gychang | Full Range | 8 | 13th November 2006 04:28 PM |
| piezo tweeter question | zobsky | Multi-Way | 9 | 27th September 2005 07:31 AM |
| piezo tweeter resistor | UNDERSTANDIN | Multi-Way | 4 | 23rd September 2005 07:37 AM |
| Which value resistor to use with piezo tweeter | Bull | Multi-Way | 0 | 14th January 2003 08:56 PM |
| Page generated in 0.12749 seconds (73.30% PHP - 26.70% MySQL) with 11 queries |
