Hi
I posted this question a while back but didn't get much response. I did get one but I guess I am looking for more opinions just as backup.
I am building an line array with Fountek Neopro5i's - 18 of them.
I think they are a little unusual in that they have a binding post connection not a solder tab.
How would I connect to these to minimize a loose connection on the inside of a sealed box?
I imagine I can't solder directly to the binding post as that is way too much metal to get hot enough to make a good joint.
Is just tinning the wire and then balling it a bit and then cranking down on the binding post really fool-proof enough?
I suppose I have never actually had a bare wire connection come loose through vibration but I want to make sure.
