Well i'll be getting a TA2020 Amp soon so i need a nice set of speakers.
Does anyone know what are the best speakers for they money for about 100 bucks or so. They dont need to be loud about 30rms. I mostly listen to rock music (but i want something on the warm side) so what do you suggest. If you think Ta2020 is not good enough they you can suggest somehing else hehe Thanks!!! |
#2 |
bump
#3 |
My best speakers won't be yours so there is no real answer to this question.
As I mainly buy vintage and used equipment my only suggestion would be to check out the local ads, thrift stores etc. and make sure you can listen. When others would respond and answer your question you would end up with a lot of different opinions and suggestions and none might even suggest the speakers you end up with. So imho the only answer is 'Use the ears Kitarist' May the ears be with you on your quest...
http://tda1541a.com The Final List |
#4 |
Maybe these, since you are from europe: http://www.lautsprechershop.de/hifi/ct230_en.htm
or these (propably too small for rock) http://www.lautsprechershop.de/hifi/ct193.htm 100$ for 2 Speakers will be not enough I am afraid. Better buy used speakers instead? Regards, Micha |
#5 |
If I was given let's say $60 to build a pair of speakers, then this would be the best :
http://attlid.eu/p_swift.html
http://gainphile.blogspot.com |
#6 |
Who is going to tell Gainphile that one driver alone is US$50?
#7 |
I bought a pair of mine for $40, and that was aussie $ too
Mine is the round 3" version (TangBand W3-1364) Mind you I have compared this with SF concertino, and there's nothing wrong with it on appropriate SPL. On some are it actually won (not as laid-back, but no hf sparkle).
#8 |
btw. I looked at PE and they're only $29 each, so $60 a pair is correct.
http://www.parts-express.com//pe/sho...ewRand=5388457 However the australian price had gone up to A$70 each . I did buy them when AUD was strong against the USD.
#9 |
Yeah, that's a cutie (about US$26 at PE), and I would mind having that in my center channel to replace the W3-881S in there now.
#10 | |
Poor Kitarist listening to
![]() As Tosh says, using it for a center channel sure would be good but I can't imagine any rock-warmth coming from these cute midgets.
| 5.1 DIY kit with on PA speakers (or good & small DIY kit with PA speakers) ? | jm_kzo | Multi-Way | 54 | 22nd April 2009 07:54 PM |
| Advice on what speakers to build, $400 price cap | santiu | Multi-Way | 19 | 29th December 2006 08:55 PM |
| PC-speakers + small amp (key words: small, cheap) | rho | Multi-Way | 8 | 18th May 2006 01:19 PM |
| (very) small speakers... | ALFIrE | Multi-Way | 11 | 1st July 2004 01:44 PM |
| Best small speakers | sparkle | Multi-Way | 10 | 27th May 2004 11:37 AM |
| Page generated in 0.10741 seconds (80.25% PHP - 19.75% MySQL) with 11 queries |
