Old 5th May 2009, 01:15 PM   #1
Default Dual 16 ohm woofers for OB
My current OB setup is a three way with an ATC 15" woofer taking care of the low end. Not exactly the best match since the Q is quite low.
Two 16 ohm woofers in parallel, Q of 0.4 or higher would be better. I know of the AE Dipole15 but sensetivity is not great and the Q is 0.9 or something like that - too high I fear.
My best bet at the moment is Volt Ps15/250 which can be had at 4/8/16 ohm.
http://www.voltloudspeakers.co.uk/Ab.../about_us.html
Kind of hard to buy this speaker, so I am open for suggestions.
Cheers
Kris
Old 5th May 2009, 01:35 PM   #2
tinitus is offline tinitus  Europe
Search on "T-bass" by Graham Maynard
Lots of information about T-bass in other OB threads
Many positive reports, and enough reading fore a couple of days
Old 5th May 2009, 04:11 PM   #3
Rudolf is offline Rudolf  Germany
Rudolf's Avatar
Default Re: Dual 16 ohm woofers for OB
A man has to fight his fears.
So why do you believe a Q of 0.9 is too high? If you start with a driver with a Q of 4, you need to EQ it, until itīs bass response looks like that of a Q=0.9 (at least) driver. Otherwise it will not work for OB.
www.dipolplus.de
Old 5th May 2009, 07:00 PM   #4
ScottG is offline ScottG  United States
Cheers
Kris
This really depends on what operating pass-band you want it for. IMO 60 Hz is about as low as you need to go to get all the benefits of an OB design.
Eminence Delta, Jensen Neo, Weber.. etc. For non-"guitar" drivers consider adding some resistance to the BD-Design BD-15.
If you want to go lower however, then consider this solution:
http://www.gr-research.com/index.asp...ROD&ProdID=141
and:
http://www.gr-research.com/index.asp...TS&Category=12
Note the statement at the bottom of the woofer page:
"..Two or three of these woofer can give you a flat response to below 20Hz, with great control, good output levels and with no enclosure. There simply is no better open baffle low frequency driver on the market."
perspective is everything
Old 5th May 2009, 10:48 PM   #5
Telstar is offline Telstar  Italy
I'm on the same boat, but I'm looking for the tightest possible bass, with smooth integration around 200hz with my narrow OB.
I'm shortlisting some units from Beyma, PHL and others.
Shipping of the GRs from the US kills the budget, becoming a hefty $970+vat+taxes for 4 pieces. They do have the best lower extension, as claimed.
The response of the inner ear extends to at least 200khz - Dr W. Tempest
Old 5th May 2009, 10:49 PM   #6
..a single Pyle Pro 21" might serve as a suitable alternative to 2 15"er's. Or if you are really hurting for cash consider the Goldwood 18" that MJK uses.
Old 5th May 2009, 11:02 PM   #7
Italy? Narrow Baffle?
Sica in Italy makes Jensen. (..not suitable for low freq. extension however.. but the most eff. OB config. you can get.)
Old 6th May 2009, 07:28 AM   #8
They have nothing with a Fs <50hz or something. So, no woofers in the current Jensen lineup. As said, I need 30-200hz.
BTW I didnt know they were italian, although Sica sounded like.
Old 6th May 2009, 08:06 AM   #9
Default Re: Re: Dual 16 ohm woofers for OB
I know of the T-bass. Only usable with solid state amps. I on the other hand only use valve amplification.
I am using passive x-over and eq at the moment hence the need for a large coil in series with the woofer. This will push Q further upwards. While I haven't really heard a 1+ Q speaker in OB, the under dampened sound is not really my cup of tea.
and:
As I failed to mention in my initial post that I rely on tube amps which demands high sensitivity speakers. Ultimately I want the twin woofers to cover the 30 to 500 Hz range with good sensitivity. My speakers are 35" wide shallow U-baffles with rounded edges.
best
Kris
Old 6th May 2009, 12:26 PM   #10
Default Re: Re: Re: Dual 16 ohm woofers for OB
Kris
Up to 500hz?
Ultimately use only one woofer
Double woofers that high is a compromise, especially when big
Alternatively, use a SUB
Dual woofers in OB v single Stuey Multi-Way 77 14th March 2012 01:41 AM
Some questions on dual voice coil woofers Fanuc Multi-Way 4 5th February 2009 11:58 PM
dual voice coil woofers el`Ol Multi-Way 0 21st January 2006 09:22 AM
Looking for tower speakers design w/ dual woofers JojoD818 Multi-Way 16 28th November 2003 02:25 AM
Page generated in 0.12222 seconds (83.22% PHP - 16.78% MySQL) with 10 queries
Copyright Đ1999-2012 diyAudio
