#21 |
diyAudio Chief Moderator
To measure in the farfield transition you would need 5 times the woofer's diameter as measuring distance (rough rule of thumb). 50cm is a bit short.
#22 | |
Didn't know the crossover came with a basic free software. That's nice. With 16 biquads per channel, you can do a lot. Some of the DDX class-d controller chips have 10 biqauds per channel, so one might be able to get results like this straight out of the amp. Fun!
Take the Speaker Voltage Test! |
#23 | |
I will measure tomorrow night again. On/Off axis plus different lenghts. |
#24 | |
And?
( (( KUGELWELLE )) ) recent projects :OB-mk1 /fatboy / monitor-xl / Horn-AM / dappolito / td124-mk1-rb301 / Hybrid-pse / Vfet |
#25 | |
****, I need 28h a day.... |
| Beyma 8AG/N horn or "the Viech" | Cyburgs | Full Range | 103 | 22nd April 2012 11:08 AM |
| Need your opinion, how small gain can I use with LM3886 (how close to "flat amp")? | danielwritesbac | Chip Amps | 20 | 30th November 2008 12:27 AM |
| How Flat is "Flat"? (XT18WO + 27TBFC-G = MTM) | zenon | Multi-Way | 3 | 21st January 2007 03:15 PM |
| Project "The Drummer"-Flat DIY sub driver | ZuMbAiU | Subwoofers | 0 | 28th January 2006 10:40 AM |
| Page generated in 0.07717 seconds (72.22% PHP - 27.78% MySQL) with 11 queries |
