Flatter than flat. PHL 10" and Beyma 1,4"
Old 5th May 2009, 11:20 AM   #1
Lindell is offline Lindell  Sweden
Default Flatter than flat. PHL 10" and Beyma 1,4"
I'm messing around with 1,4" drivers and I just built a box like this:
Measurements done at 2m hight and 50cm on-axis in our huge recording studio room, hence the great bass measurement.
I will use the loudspeaker for critical'n'loud and emotional monitoring in my recording studio.
Box is 80l tuned to around 30Hz. 10" woofer is PHL 3002. 1,4" driver is Beyma CP-755Ti and Horn TD-385. -3db @ 25Hz and -3db @ 21kHz.
DSP processor is Ground Sound DCN23. I can post the dsp settings if anyone wants to build it.
The sound is amazingly fast and "in yer face". Tight, deep and powerful bass. Stereo image is very accurate. Depth is amazing.
I was very sceptical to 1,4" horn drivers but they do deliver and very live like sound.
Pretty excellent graphs eh?
Rock on,
Old 5th May 2009, 11:29 AM   #2
wigginjs is offline wigginjs  United States
wigginjs's Avatar
Wow, yes, most impressive. I am amazed by the depth available from that 10.
Old 5th May 2009, 12:27 PM   #3
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Where is the reference axis vertically? Between drivers or on horn's centre? Any lateral off axis graphs to see? 22.5-45deg would be informative. How much the dsp pushes the 10 inch for bass aid? Yes it would be very informative to see the dsp curves and maybe an impulse graph. Nice looking btw.
Old 5th May 2009, 01:00 PM   #4
ttan98 is offline ttan98  Australia
My speakers configuration is similar to yours,
ie
10" alnico woofer
B&C De250 compression driver
RCF H100 horn
all housed in a 70l bass reflex cabinet
I was able to get fairly flat too, sounds very good as well, open and dynamic. A worthwhile exercise.
I am currently designing and building another system(open baffle), trying to make the sound better than above system.
Happy listening.
Old 5th May 2009, 02:10 PM   #5
Salas,
Microphone is pointed exactly between the horn and woofer at 50cm distance.
I will measure off-axis respons as soon as I can.
There is no bass boost to get so low. The cab and port makes for the lowest freq's. I have only notched it flat.
You can see the impulse respons above.
L
Old 5th May 2009, 02:11 PM   #6
Thanks,
Yeah me too....
Old 5th May 2009, 02:32 PM   #7
qquickk is offline qquickk  United States
Is that a coated paper cone? Great extension for 80l.
Old 6th May 2009, 02:32 AM   #8
winslow is offline winslow  United States
Nice compression drivers. I have a set of the neo motored versions and find them to sound very good.
Old 6th May 2009, 02:50 AM   #9
BHTX is offline BHTX  United States
BHTX's Avatar
Default Re: Flatter than flat. PHL 10" and Beyma 1,4"
Step response is mangled. Woofer is severely lagging behind.
Old 6th May 2009, 05:15 AM   #10
BHTX's Avatar
I was just kidding btw, kinda being a smart ***. Looks very nice.
Flatter than flat. PHL 10" and Beyma 1,4"Hide this!Advertise here!
Beyma 8AG/N horn or "the Viech" Cyburgs Full Range 112 12th August 2012 01:57 PM
Need your opinion, how small gain can I use with LM3886 (how close to "flat amp")? danielwritesbac Chip Amps 20 30th November 2008 12:27 AM
How Flat is "Flat"? (XT18WO + 27TBFC-G = MTM) zenon Multi-Way 3 21st January 2007 03:15 PM
Project "The Drummer"-Flat DIY sub driver ZuMbAiU Subwoofers 0 28th January 2006 10:40 AM
Copyright ©1999-2017 diyAudio
