Hello guys..I am new in here and i really apreciate all the info i can find here!..
So here is my questions..A friend gave me for free a brand new pair of 4" Focal - Access 100 CA1 http://www.sonicelectronix.com/item_...l+100+CA1.html .. that what i need to do is build a small hifi system for my worklab..so i am looking for the ideal box for these speakers.i intend to build it using plexiglass 1cm thick mainly for good looks....so can someone tell me what size the box should be for optimal acoustics?.i searched through the net but i couldnt find something specific.. any comments are welcome! by the way, these speakers will be driven by a Chinese amp using the very well known Tripath ic's, giving about 15-20Wrms..
#2 |
on the poduct datasheet it suggests a 30Liters sealed enclosure!!!..isnt it too much?..my Focal Access 12" subwoofers needed 35Lts vented..
#3 |
Speakerholic
They are a car speaker. Being a 4" driver means it likely has a high Qts to give it some bass sound in the door or back shelf. A high Q often means a high Vas, unlike that of a longthrow woofer.
#4 |
Specifications are desirable to design a box for optimum bass. After a short google search, I found this link for specs: http://www.focalaustralia.com.au/pdfs/acc_100CA1.pdf
The human capacity for self delusion is nearly infinite. |
#5 |
IB is best. Don't put it in an enclosure, unless you have no other choice. It'll be under damped when you do. It could be much worse though.
#6 |
well acording to the specifications a 30Lt box is suitable but its way too big from what i am thinking..i was thinking something around 4-5lts.
#7 | |
IB = an infinite number of liters. |
#8 |
then these are useless speakers for me...damn..anyway thanks for your help guys!
#9 |
You can certainly put them in a 4 or 5 liter closed box. Two things will happen, the frequency response in the low end may have a peak, and the system won't go as low as it might otherwise. In a 5 liter box, according to my software, the -3db point is about 100Hz.
#10 |
well if it can go down to 90-100Hz i believe it will be ok...i dont expect something extraodinary...that what i want though is great mid bass and midrange performance...i like Metal, folclore and rock music so i think it will be ok..i will use 10mm plexiglass and when i am done i will tell u my impressions!..
| what type of digital coaxial cable is "in" right now? | RemoGaggi | Digital Source | 1 | 12th December 2006 02:03 AM |
| suspending a small tweeter in front of woofer for "coaxial" effect? | bikehorn | Multi-Way | 3 | 2nd January 2006 02:04 PM |
| Focal "W" cones as seen on JM Labs Utopia series | KT | Multi-Way | 1 | 19th September 2005 12:52 AM |
| WTB: Focal & Audiom & Volts 11", 12", 13", 15" woofer | gengis | Swap Meet | 0 | 17th March 2005 02:29 AM |
| "Coaxial" audio output on DVD player - what is data format? | Circlotron | Digital Source | 3 | 27th February 2003 04:34 PM |
| Page generated in 0.10990 seconds (80.87% PHP - 19.13% MySQL) with 11 queries |
