Has anyone used these with an electronic crossover and a NOTCH Filter so that these could be run to 6K or so?
Would this affect sensitivity. |
#2 |
I think some information is missing? Is there a particular driver you want to run to 6kHz?
You are talking about an active line level electronic crossover I presume, but with addition of notch filters to control driver breakup? If this is the case, sensitivity is unaffected (level at the notch freq is naturally reduced!) I have used one, in my case to control the breakup of a metal coned woofer (Hi-Vi M8a), works very well. Here is the schamatic for the circuit I used: ![]() When designing your own filter as a rough guide the ratio of R4 and R3 controls notch depth (attenuation), C2 effects notch frequency and C1 notch width, but all of these are quite interactive so I reccomend you check it in software like this |
#3 |
The speaker is a Dayton RS52 dome midrange. It has nasty breakup at 13000Hz or so.
#4 |
Ah, well that is the same midrange driver I am using!
I tried a 13khz notch but in practice it didn't seen very required. I also found that it added a lot of noise and seemed to resonate a bit at the 13khz frequency, though that may have been in part due to the breadboard construction. I decided it was such a high frequency that it wasn't of much concern in my application. Anyhow, in my application I am crossing over at 4.7kHz with 24db slopes. If you are going for 6k at 24db you should be ok, though 6k with less than 24db might be an issue. I found the filter created phase shifts even at my crossover point, so look out for these. Here is the schematic for the filter I tried (values needed altering on breadboard due to stray capacitances):
#5 |
Wow, All my questions have answered.
Mitch |
| Parallel or serial notch filter in a crossover? | Jonasa | Multi-Way | 12 | 3rd May 2012 10:54 PM |
| need help wana change 60-Hz twin-T notch filter to 279 Hz filter | prorms | Solid State | 0 | 9th February 2008 11:38 PM |
| Can Zaphs notch filter be used without the BSC filter? | GuyPanico | Full Range | 0 | 21st July 2007 01:27 AM |
| fe 103 notch filter | Jhovis | Full Range | 6 | 16th April 2007 09:43 PM |
| Notch filter for crossover-good idea? | kelticwizard | Multi-Way | 2 | 21st September 2002 04:03 AM |
| Page generated in 0.09099 seconds (75.94% PHP - 24.06% MySQL) with 10 queries |
