Hiya
Just wondering if anyone knows of or can recommend a "class a" amp to drive thise minipod speakers http://www.podspeakers.com/Products/Minipod.aspx Shape 2 way reflex, abs cabinet. Applications Stereo arrangement, AV, 5.1, multimedia, near field monitoring for studios. Frequency Minus 3db at 55hz and 22khz. Sensitivity 90db spl (1w @ 1m) 4 ohm. Sound Compatible with amplifiers from 10w - 100w output. Cheers |
#2 |
Interesting speakers, sure I've seen them before somewhere. I think they're in one of the apartments in Freinds or something obscure!
Anyhow, on what criteria are you basing your choice to use a class-A amplifier with these speakers? Is it something that's been reccomended to you? Class-A isn't especially popular as it is highly inefficient so costs a lot to manufacture and to run. Most commercial amps are class-AB. Class-A may indeed give you the best performance as it eliminates crossover distortion, but debatably this is insignificant in modern well designed class-AB amplifiers. These speakers arn't optimum candidates for class-A amplification I wouldn't say. The sensitivity is quite average and the 4ohm load is not one which class-A amps typically drive (most Hi-Fi ones are designed for 8ohm). I can't really think of any suitable class-A amplifiers for these, though you could build one if that was something you wanted to do (good electronics experience needed really)? Otherwise, pick up a good typical class-AB or class-D amp of which there are many options around! |
#3 |
Have you checked the 'Pass Labs' section? Should keep you busy long enough for the urge to pass. A Zen v1 or beyond will be much better than these deserve. I have a 4-channel Zen v1 that drives easy 4 ohm loads pretty good from a single channel and even better when paralleled. It's a simple circuit that is not critical about exact component values or ps voltage and can be 'de-tuned' for a less-than-huge heat sink. Perhaps you've heard of it? Zen...
| Class A amp and Minipod speakers | Rixsta | Solid State | 0 | 27th April 2009 08:20 PM |
| Class D for electrostatic speakers | koldby | Class D | 23 | 4th December 2007 04:10 PM |
| Class A for sensitive speakers | XELB | Solid State | 4 | 25th November 2005 06:25 PM |
| Class D, Which speakers ? | amolan | Class D | 4 | 2nd November 2005 05:50 PM |
| speakers for class A ? | felixx | Tubes / Valves | 1 | 6th May 2005 12:37 PM |
| Page generated in 0.08174 seconds (69.45% PHP - 30.55% MySQL) with 10 queries |
