Hi Guys,
I originally want to buy a pair of woofer, but bought a pair of 418B without checking the specification of the speakers. I still wish to make use of them, if possible as a woofer, if not please advise what configuration will be best for this speakers. Thanks in advance Albert |
#2 |
Greets!
It's a musical instrument driver best suited for a lead guitar amp or similar, so has a ~45 Hz Fs, ~0.3 Qts, high Vas (~250 L?) and very small Xmax (1.3 mm) IIRC: http://www.lansingheritage.org/image...-mi/page04.jpg It has high efficiency, so if you drive it with a high output impedance amp it should play down into the 30s at modest SPL if the box is big enough and tuned low enough. Coupled to an Altec 811 horn and 1200-1500 Hz XO it will make a nice mini-M19: http://www.lansingheritage.org/html/...s/model-19.htm GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#3 |
GM,
Thanks a bunch and nice to have you along. According to the catalog, it seems to me the dimension including the 811 horn at the top. Would you be kind enough to show me the box dimension for the 418B as well since I'm a old newbie and a copy cat to be exact. Albert |
#4 |
I use a pair of these in some monstrous Karlson enclosures . . . I only use them for the sub-120 hz material, as I have some DIY open baffle line arryas for the rest of the music spectrum.
they are SUPER efficient, and have some serious snap (and thump for that matter) I don't like using them much higher than 150 - 200 Hz as I think they get kinda honky (they are MI speakers after all . . .) I've never actually measured their frequency response in the Karlsons, but they seem to drop like a rock around their Fs . . .not a big deal for me really . . . They like lotsa clean SS power, but I have used them with little tube amps too . . . best sound to date from them came from a BIG pro audio mixer putting out 400 watts RMS per channel . . . . ridiculous SPL levels . . . and great midbass snap in the Karlsons . . . these Altec's really like to be spanked ! I ran the amp so it was just under the clipping threshold for about 5 hours at a DJ gig, and they could've played for DAYS at that level with no sweat. good luck and have fun |
#5 |
Thanks so much for the suggestion, but I intent to run them with my 2A3 and or EL84pp
#6 |
Speakerholic
Moved to loudspeaker section.
#7 | |
OK, so you're saying you want to make a mini-M19 complete with 811 horn system or just a woofer cab or.......? Regardless, I'll need your amp's output impedance (not their tap ratings) or at least their damping factors (DF) to ensure the cab is large enough to keep its bass line from sounding too 'warm'/'bloated'/'loose'. Otherwise, all I can do is assume a 'worst case' size tuned to Fs and you may have to reduce its internal size and re-tune the vent. Also, any width/depth height preferences/limitations? GM
#8 | |
#9 |
GM, & bottom feeder.
The output transformer on my 2A3 are 2.5K double C core with 8R secondary and the EL84PP with a pair of Edcor 7.6K primary and 8R secondary. GM, I personally love to make it a bass only speaker, so I could play around with different combination. Albert |
#10 |
GM,
I thought I didn't answer your questions, but I don't know what are the damping factors of two of my amps. The EL84pp is ' The Bovois Vally' designed by Morgan Jones. A friend of mind gave me the schematic, but without any description. Size of the box is not too critical. Regards Albert |
| Altec 601 | Ilianh | Multi-Way | 1 | 8th May 2012 02:59 AM |
| Altec 408-A | Decker | Full Range | 0 | 22nd February 2009 09:30 PM |
| Altec 811B horns and Altec 414z 12" Speakers | xecluded | Swap Meet | 0 | 21st September 2008 05:21 AM |
| altec 807-8z | AudioGeek | Multi-Way | 42 | 9th July 2007 05:38 PM |
| Altec to JBL | santosa | Multi-Way | 1 | 18th July 2005 01:41 PM |
| Page generated in 0.11164 seconds (79.12% PHP - 20.88% MySQL) with 11 queries |
