Old 28th April 2009, 06:12 AM   #1
Tino is offline Tino  Canada
Default Which shape cabinet for 2 way speaker
Hi guys, I have some pre-cut MDF that was for some other project but it works out nearly to the volume I want for a Vifa 2 way setup but want to see which way you guys would choose as far as mounting the drivers.
I can either have the speakers being short and deep or tall and not so deep. Same box really but just mounting the drivers on another panel. I'm thinking the short speaker might be better because there might be less flex on the panel that has the drivers due to the fact that its smaller. I'm also thinking that I could use a slightly larger port without worrying about port depth since front to back, I have a lot of space to work with.
So is one way better than the other? The wood is 5/8" MDF by the way.
Any suggestions welcome.
Old 28th April 2009, 06:21 AM   #2
brsanko is offline brsanko  United States
brsanko's Avatar
Send a message via MSN to brsanko
depends where you want to put them. If they're going on the floor make them taller, if you're putting them on stands deeper may work better. Figure out which orientation brings the drivers to ear height in your listening position. Don't forget you can always put an elbow on your port and it doesn't have to exit on the speaker baffle.
PASSIONN
Old 28th April 2009, 06:38 AM   #3
Thanks for the reply. I'll be building my own stands so height is not really a problem. As for the port, I think I want the port on the front because in the smaller room, Ive found rear firing ports usually end up giving me heavier bottom than I'd like.
I'm leaning towards the shorter, deeper setup
CNC shape cabinet? Audist Multi-Way 20 19th January 2006 09:12 PM
Speaker Cabinet InfinityPWS Multi-Way 2 13th January 2006 02:11 PM
Kef Cadenza.....New Cabinet shape. Paul Dimaline Multi-Way 2 3rd December 2005 04:50 PM
Round; Non-retangular shape speaker URL gengis Multi-Way 2 15th March 2005 11:19 AM
help.. cabinet volume, shape, aghh! seewot Multi-Way 7 15th July 2004 06:32 PM
Page generated in 0.06785 seconds (83.24% PHP - 16.76% MySQL) with 10 queries
