I need a switch. If I knew what to call it, I could probably find one easily.
I obtained a very nice older amplifier with only one set of speaker outputs. I have two sets of speakers, in different rooms and would like to be able to switch from one set to the other. My previous amplifiers always allowed for this option. I would like a simple switch that would allow me to hook up an output cable from the amp to the switch which would have two outputs,one for each set of speakers. It seems like it should be trivially simple. Thanks for any suggestions. |
#2 |
Sounds like you need a high power Auto switch, quad pole centre off.
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING" |
#3 |
frugal-phile(tm)
4-pole double throw for A-B switch, or the same with centre off as per moondog.
The actual switches most often used in old receivers don't switch ground, so you could probably get away with a 2-pole switch in a pinch. dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#4 |
parts express will probably have something.
Here is an Aussie version: http://jaycar.com.au/productView.asp...h&form=KEYWORD col.
http://www.minirig.org.au |
#5 |
2 Way Speaker Selector Switch !
That's the ticket. Just needed the name, the rest is easy. I found one right away. Thanks you all. |
| Tech advice needed for Rotel RB-850 | pjeaton | Solid State | 20 | 5th October 2006 09:54 PM |
| Tech help needed Threshold S/300 MkII optical bias | georgehifi | Pass Labs | 4 | 18th January 2005 06:49 PM |
| Tech help needed Threshold S/300 MkII optical bias | georgehifi | Solid State | 15 | 17th January 2005 01:30 AM |
| Speaker Tech needed in Los Angeles area | dmfraser | Multi-Way | 2 | 3rd November 2004 11:18 PM |
| Page generated in 0.06732 seconds (81.03% PHP - 18.97% MySQL) with 10 queries |
