help me choose between 2 Troels Gravesen 3_way designs
Old 26th April 2009, 04:34 AM   #1
zimjj is offline zimjj  United States
Default help me choose between 2 Troels Gravesen 3_way designs
Iíve picked two completely different design concepts and would like to hear the pros and cons of each. Both are from Troels Gravesen the Danish designer. I donít want to build exactly as he designed them; I just fell in love with the cabinet designs. I want to choose other drivers, recalculate the volumes and do my own crossover (Iím thinking of going active).
The first is the Ekta Grande a very sculptural narrow baffle design. The second is a very wide baffle design, the Poor Manís Strad, it is a copy of the Sonus Faber Stradivarius ($40,000.00 / pr). They are both listed in the included link. He has pictures of a few examples across the top of the page and if you click on them they will take you to the design description. The Ekta Grande is second from the left and it will take you to a build description by Jesper Spohr who built Troels design. The Poor Manís Strad is 4th from the left and it will take you to a picture of one made by Kari Koskela of Finland, which has a link to Troelsí build description.
You will see from Troelsí page he is a very prolific designer and he has enough creds, at least in Denmark, that he got SEAS to manufacture a driver to his design for the DTQWT, check it out. Itís a huge speaker, but if you want to build it as is you will need to buy a kit from Jantzen.
http://www.troelsgravesen.dk/Diy_Lou...r_Projects.htm
Iíve selected a range of drivers I would like to choose from but, depending on how this thread goes, if anywhere, Iíll save them for another post. Weíll also need to talk about active crossovers.
I hope this stimulates some conversation!
JohnZ
Old 26th April 2009, 09:01 AM   #2
MadMutt is offline MadMutt  Australia
So whats the question ???????
Old 26th April 2009, 02:38 PM   #3
My question is: What are the pros and cons of a speaker with a very wide curved baffle vs one with a very narrow baffle.
Everything's a compromise, so each is probably weak in one area and strong in others. I've never actually heard a wide baffle such as the Sonus Faber Stradivarius so - is it strong reproducing a symphony orcestra in a concert hall and maybe not so strong with a single vocalist? Which would be better in a home theater?
So, if my use will be 80% home theater and HDTV, with the other 20% divided among a wide range of musical genres which should I build? I know there is no definitive answer I was just hoping for a conversation with people who know more than I.
Thanks,
JohnZ
Old 26th April 2009, 06:41 PM   #4
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
JohnZ
Measurements and xo design will take care of any issues
sometimes we know very little, and sometimes we know too much
Old 27th April 2009, 12:08 AM   #5
PeteMcK is offline PeteMcK
Wider baffle makes it easier to deal with Baffle Step correction - in fact may not need it at all
Impedance varies with frequency, use impedance plots of your drivers and make crossover calculations using the actual impedance of the driver at the crossover frequency
help me choose between 2 Troels Gravesen 3_way designsHide this!Advertise here!
Any Experience with Troels Gravesen Designs??? mlammert Multi-Way 57 12th December 2012 02:53 AM
AV Enthusiast Interview: Troels Gravesen mlankton Multi-Way 4 27th April 2011 05:18 AM
Troels gravesen PMS: riddle this for me matsuru Multi-Way 3 5th January 2008 01:45 PM
Troels Gravesen W1500/97 monitor fgroen Multi-Way 9 10th March 2007 04:53 AM
Copyright ©1999-2017 diyAudio
