Ok, wild idea (sort of). I'm sure many of you are going to read this and think either: a) "that's a dumb idea and it won't work because...." or b) "that's a great idea, but who is going to implement it?". Well, maybe you're right, but I think it's an excellent idea and I want to go ahead and throw it out there to get some feedback and maybe spark some interest.
Would it be possible to take the discrete functional circuits (input buffer, 12db/oct slope filter, Linkwitz Transform, notch/peak, etc.) combined in the "Active Filter 4 " and implement them independently on small, uniform sized PCBs? Then added headers at both ends of them (examples below) to allow them to be "plugged" into each other and pass the signal and supply voltage between each other. This way you could configure as many of them as you like in what ever order you like. The PCBs would connect horizontally and not stack vertically. A PCB could be created that routes the traces in the shape of a "C" so that the direction of the PCB flow could be "wrapped" and you wouldn't end up with one huge line of PCBs. They would function like active filter "legos" that could be combined in an endless number of combinations. Also, it would be much easier to make changes to your filter. Want to add a notch filter? Just plug it in... Get the picture? Thoughts? Anyone want to design the boards and do a GB? =) Molex 90121-0125 Sullins PPPC051LGBN-RC Obviously you would still have to calculate the values for each individual filter board to make the filter you desire. Hopefully the small boards would be fairly inexpensive so it would be easy to build a few and then swap them out to mix and match to preference. So, build a couple notch filters with different Q's and swap them to see what they sound like. If you end up with extra filter blocks you could use them in another project or possibly, if enough people are using them, trade with other people. |
#2 |
frugal-phile(tm)
I have had similar ideas.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#3 |
Dave:
Having confirmation from a proven thinker like yourself is encouraging! Did they ever amount to anything tangible? |
#4 |
W, your idea will work fine if you implement it properly. For example, I would have some small local decoupling PS caps on each board, and would prefer if all the earths returned directly to a single point.
I have a pro active xover that uses a large PCB that contains power tracks and paths for the audio, but the SK24 filter stages are all on small daughter PCBs connected via SILs. Frequency is changed by component substitution with the Rs and Cs on small stand offs to allow easy soldering access. |
#5 |
Ok, maybe a different question. Who would purchase something like this?
#7 | |
The pro unit would be maybe 15 years old. I can't be bothered any more, so I bought a few DCX 2496 instead. |
#8 |
Aww... DCX2496?!
I don't know. Something about me doesn't like the extra D->A A->D conversion and also, how do you control the volume? Don't you need a 6 channel attenuator after the DCX? |
#9 | |
Control the volume before the DCX. |
#10 |
I think its a good idea - right now I use my computer to do what the DCX does, but when I have the design finalized, I'll do an analog equivalent of it. I guess I would rather have a few more opamps in the signal path than an extra A > D > A.
Go for it. Also, its possible to do several different filters around one opamp, which is how I'll do it.
double complete rainbow all the way!! |
| Idea for anti jitter filter | Bernhard | Digital Source | 39 | 3rd February 2011 03:00 PM |
| An active box idea based on KEF Q1. | Dxvideo | Multi-Way | 2 | 13th July 2009 06:53 PM |
| Active Box Idea | Dxvideo | Chip Amps | 15 | 27th August 2008 12:15 PM |
| active filter from rod elliot and sub filter questions | wuffer | Parts | 0 | 2nd October 2005 01:12 PM |
| Page generated in 0.11096 seconds (80.10% PHP - 19.90% MySQL) with 11 queries |
