Old 24th April 2009, 10:54 AM   #1
Default Low XO point / waveguide
Which tweeter wille be able to go very low with XO point.
xt25 in 12in waveguide experiment
XT25 generally has quite bad THD results, but in this experiment it is much better.
Had someone tried making very low XO point with waveguide?
Old 25th April 2009, 03:01 AM   #2
gedlee is offline gedlee  United States
Your link is bad and your question is unclear.
Old 25th April 2009, 08:03 AM   #3
There have been several attempts to do that. See for example Zaph's Waveguide project for a start:
http://www.zaphaudio.com/Waveguidetmm.html
or Joe Rasmunssen Elsinores(which went from Vifa Xt25 to Peerless HDS):
The "Elsinore Project" Thread
Basically, you can try a waveguide with pretty much any tweeter - but it has to have at least acceptable low distortion at the bottom end.
I have tried it myself with XT25, but ended up preferring the sound without the waveguide(and higher crossover point, currently 2.5 kHz LR2): it was not a thorough test and I might have just not gone far enough to do it right, but I have found the sound without the waveguide more natural and dynamic. Maybe one day I'll give it another try.
I don't believe in audio believings.
Determining Xover Point with Waveguide Horizons Multi-Way 14 19th November 2008 04:43 PM
Wire Wrap connections for point to point mashaffer Tubes / Valves 10 7th July 2007 01:11 PM
Benifits of point to point wiring for digital circuit? MGH Digital Source 15 14th September 2006 10:17 PM
Anyone use magnet wire for point to point wiring projects? Hybrid fourdoor Parts 10 2nd February 2004 08:11 AM
Audio Note's Kit One done in point-to-point wiring Wram Tubes / Valves 18 29th April 2003 10:59 PM
Page generated in 0.06451 seconds (70.12% PHP - 29.88% MySQL) with 10 queries
