Wood Staining Question
Old 24th April 2009, 12:44 AM   #1
sdclc126 is offline sdclc126  United States
sdclc126's Avatar
Default Wood Staining Question
Hi All,
I am going to stain some light colored veneer (red oak) with a dark stain (Minwax Bombay Mahogany 1 Step). I was wondering if anyone could tell me approximately how many coats it might take to get the wood very dark, like an espresso-type dark, if it's possible? If not I retain the option of starting over with a darker veneer.
Anything I should do between coats? Minwax says to use 000 or finer steel wool, but I've done that on some tables I'm working on and it seemed to do nothing at all - I was thinking 600-grit or finer sand paper, which I'm told to use between coats of clear topcoat.
Thanks much.
Soft Dome
Old 24th April 2009, 02:07 PM   #2
mattmcl is offline mattmcl  United States
It depends- I would guess you're looking at five or six coats. What I do is plan for six coats, use regular very fine wood sandpaper after the first coat, then work your way through 600, then 800, and finish with steel wool.
I believe that One-Step has the polyurethane built in, in which case you'll want to do thin coats so it doesn't build up anywhere. The trick to finishing is lots of thin coats, with lots of sanding in between.
Old 24th April 2009, 04:21 PM   #3
sdclc126's Avatar
Hi matt,
Thanks for the info - I'll plan on 5-6 coats - I hadn't realized they needed to be thin - I'd assumed the opposite.
Yes - the 1-Step has poly mixed in - but I'll still be using clear poly for the final finish.
Cheers
Soft Dome
Old 24th April 2009, 04:41 PM   #4
BillEpstein is offline BillEpstein  United States
BillEpstein's Avatar
Gadzooks, what a lot of work!
Oak is an open-pored wood that accepts oil-based pigment stains like the Minwax rather badly. Blotches guaranteed unless you use a pre-stain conditioner but then it won't get very dark.
Get to a Rockler or Woodcraft and buy DYE Stain liquid or powder in the color you want. Wipe on, wipe off. SAnd with 220 Garnet paper. Topcoat.
Old 24th April 2009, 04:54 PM   #5
Lee35210 is offline Lee35210  United States
Newest issue (June 2009) of Popular Woodworking has an article on ebonizing wood that looks fast and simple and nice.
Been there, Heard that, Forgot what I was listening to!
Old 24th April 2009, 04:58 PM   #6
VictoriaGuy is offline VictoriaGuy  Canada
I agree with Bill- the Minwax is actually a colored finish, not a stain and will take a lot of buildup to get the dark color you are looking for. (You are probably looking for the color that you see on Mission/Craftsman/Morris furniture, which is actually produced by using ammonia in a 'tent' but that's another story...)
Use stain, which is controllable by adding more or wiping off with solvent. When the color is right, topcoat.
Cheers
John
Old 24th April 2009, 05:00 PM   #7
sdclc126's Avatar
Hi Bill,
There's a Rockler in San Diego and I've been there several times; I've seen the DYE stuff but thought maybe it was a concentrate that needed to be reduced or something.
It certainly sounds like a great alternative, so I'll go talk to them. I'm staining a very large coffee table in addition to my speakers and the less work the better - I've gotten very frustrated with some other veneer projects I've tried - yes too much time and work and I want to get these done.
One question - I've already put the first coat of stain on the tables - can DYE be put over it or should I start over with new veneer, or sand & dye, etc?
Soft Dome
Old 24th April 2009, 05:18 PM   #8
sdclc126's Avatar
Lee - thanks - I'll look for the magazine when I go to Rockler!
VG - thanks too - looks like I'm just using the wrong stuff in the first place - I haven't been using REAL stain/dye. So I'm just going to start the project fresh. At least I haven't put any veneer/finish on the speakers yet - I'll do some test spots on the veneer first so I know what I'm doing before I start gluing it down.
Soft Dome
Old 24th April 2009, 05:50 PM   #9
hoyo55 is offline hoyo55  United States
Send a message via Yahoo to hoyo55
I thought I'd mention that the 1-step stain/poly mixtures have a tendency to obscure the grain, since they sit on top of it. On the other hand, penetrating stains have the tendency to accentuate the grain, especially for absorbent woods like oak.
If you want to have an end product that highlights as much of the wood grain as possible, I'd recommend starting with a couple applications of penetrating stain followed by enough coats of the 1-step to get to the level of color you're after.
If, on the other hand, you want a even color that downplays the oak grain, I'd recommend going straight to multiple coats of the 1-step, or perhaps starting with a coat of sealer followed by the multiple coats of 1-step.
Old 24th April 2009, 06:16 PM   #10
sdclc126's Avatar
Well I don't mind obscuring the grain to get the dark color - I have espresso colored furniture that I'm trying to match, so the darkness is the best.
But - what is a "penetrating" stain - can you give me a brand/source etc?
Soft Dome
Wood Staining QuestionHide this!Advertise here!
Wood finishing question dsrviola Multi-Way 9 25th December 2008 10:40 PM
Need tips on OB construction and staining. GuyPanico Multi-Way 12 19th June 2005 10:28 PM
Staining wood, especially birch mazeroth Multi-Way 13 20th December 2004 12:57 AM
staining supa-roo Multi-Way 22 9th September 2003 01:10 PM
A wood finish question kneadle Multi-Way 19 17th July 2003 03:51 PM
