How big casing for loudspeakers?
Old 23rd April 2009, 09:30 PM   #1
Decriptor is offline Decriptor  Slovenia
Question How big casing for loudspeakers?
Hello,
I have a little problem here. I have found some old loudspeakers. Now I would like to put them in a casing, but I don't know how big casing I'm supposed to make. I don't have any data about the speakers I can just tell to you what that they are Jensen J310TX /150W Peak power, 45W Contionous power, 92 dB Sensitivity and I think they are 6x9 inch big.
Please help me, thank you.
Old 23rd April 2009, 09:52 PM   #2
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
Hi, being that they are a car speaker, often intended for back deck mounting, just about any large box (read 3 cu ft or more) will do. What is it you are planning to do with them? That will be important to know as you may get away with a much smaller box depending on the implementation.
planet10 needs your help:
Let's help Ruth and Dave
Old 23rd April 2009, 09:57 PM   #3
Andersonix is offline Andersonix  Sweden
Andersonix's Avatar
What Cal said: Big sealed box.
Plus if these are like all other old Jensens I've seen, the foam will be hard or rotten and not worth using or taking the trouble to make or find a box.
Old 23rd April 2009, 10:00 PM   #4
Speakerholic
Cal Weldon's Avatar
Tosh, I agree.
Decriptor, poke your finger on the surround foam and see what happens. If it fails, you have saved yourself the time building the boxes as Tosh mentioned.
Old 26th April 2009, 11:42 AM   #5
I will use the speakers for playing music from my MP3 player. I've already tested them and they play music OK for me. I know they are not some high quality speakers.
Now it would really help me if someone told me how big sealed box I have to make for each speaker. Thank you.
Old 26th April 2009, 11:52 AM   #6
MadMutt is offline MadMutt  Australia
And I quote
"just about any large box (read 3 cu ft or more) will do. What is it you are planning to do with them? That will be important to know as you may get away with a much smaller box depending on the implementation."
Thanks.......
Old 26th April 2009, 06:16 PM   #7
Speakerholic
Cal Weldon's Avatar
Meaning that if you plan to add a woofer now or at a later dater date, the box can be made smaller. You will sacrifice the low end but the woofer will look after that. If you are running them alone, put them in the largest box you can handle in the room. Otherwise scale it down to fit. Just keep in mind that as you get smaller the bass will suffer.
How big casing for loudspeakers?Hide this!Advertise here!
Designer casing Gabster Group Buys 4 8th January 2009 12:13 PM
Designer casing for sale Gabster Swap Meet 0 13th December 2008 05:04 PM
casing for cd pro 2 Pocoyo Everything Else 1 5th March 2007 04:17 PM
Casing dimensions Mlaen Solid State 1 20th February 2005 07:32 PM
