I was just wondering if anyone done a project using this idea with rounded corners on it and what the end result of the experiment
#2 |
hexagon is a 2D shape... how would the 3rd dimension look like?
#3 |
As close to regular hexagonal prisms as I could make.
http://members.optusnet.com.au/~grad...ics/HexHT2.jpg Symmetrical but irregular hexagonal prisms http://members.optusnet.com.au/~grad...mby%20bass.JPG http://members.optusnet.com.au/~gradds55/subs2.jpg and just for fun, here is a dodecahedral trucated pyramid. http://members.optusnet.com.au/~grad...rinthians5.JPG enjoy |
#4 |
Speakerholic
I knew we could count on Andy. Nice boxes my friend.
#5 |
frugal-phile(tm)
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#6 |
hexagon shaped column
#7 |
Long ago, I built some pentagonal shaped columns (odd number to avoid parallel walls). The enclosures worked well, but nothing special.
These multi-side structures can be quite rigid due to the short panel width. Very simple construction...cut the panels at the proper angles, tape the edges together with duct tape, apply glue, roll into shape. |
| Impressive built vintage laminated speaker cabinet | binarywhisper | Multi-Way | 10 | 31st May 2007 06:40 PM |
| Page generated in 0.08104 seconds (73.32% PHP - 26.68% MySQL) with 10 queries |
